Question about Gateway FPD2275W LCD Monitor
Gateway monitor flickering
Monitor flickering at all times even when not plugged into tower
  • 1 more comment
  • jcampo137 Jun 23, 2008
    yes, even when monitor not plugged into tower, it is flickering. Tried different outlet etc...all of a sudden out of nowhere it is flickering
  • pfrenelle Nov 21, 2008
    My monitor picture is "out of focus" - almost waving. I can read it but it gives me a headache. The print out of a screen is still great. I checked connections and bought a new monitor cable but the problem is still there.
  • Anonymous Dec 03, 2008
    My monitor flickers continuously on and off. i plugged into other working systems. same problem. is there a solution other than replacing the monitor?
I had an older mac Mini that would do that and could not use it with that monitor. it worked fine with my G5 powerpc, was probably a video card issue. I got it to work also by connecting with a VGA connection rather than a DVI
Posted on Jun 21, 2009
  • 3 Answers
  1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
  2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
  3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
If the above steps do not resolve the situation, please contact the Packard Bell Help line for further assistance.
Posted on Feb 05, 2009
I had this problem. i opened the monitor up and every single one of the capacitors was blown (bulged and leaky). went to frys electronics, bought new ones for 12 bucks. some soldering later and the thing works perfectly.
look into this solution before spending ANY money anywhere else. there are truly MILLIONS of bad capacitors floating around the world. google 'bad capacitors' for instructions or to find someone to do this for you.
Posted on Jan 10, 2009
    Scholar:
  • 117 Answers
You need to try that monitor on another "working" system. If the same problems happens, then it's the monitor. If it doesn't happen, then it's probably your video card.
Thank You
~~Jasta~~
Posted on Mar 24, 2008
SOURCE:
What type of pc tower is compatible with an older gateway monitor model fpd1750
Try typing in, "compatible PC towers for gateway model fpd1750" on Google.
Jun 13, 2014 | Gateway FPD 1750 17" Flat Panel LCD...
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
I dont know how to hookup my monitor to the tower
You will have two plugs coming from your monitor
One will have a blue plug that looks a little different, the other one will have a regular plug which can be plugged into your power surge or into a wall outlet.
The blue one will match up with a port on your tower. If you look on the back of the tower where all of the plugs go you will see one that looks similar but is opposite to the one coming from the monitor. Make sure you turn it to fit then screw it in and you should be good to go
Nov 06, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
Gateway FHD2400 flickering / blinking / flashing on and off whether connected to laptop or not. Only had the monitor for about a year, and I've barely used it. I connect it to my Mac Powerbook, and after...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Jan 18, 2010 | Gateway FHD2400 24 in. LCD TV
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
Flickering picture
chech out some other devices near by to the monitor, they might cause interfearence and in a result your monitor flickers.
1. If there is nay CVT/UPS near your monitor put it away.
2. If you have any speaker without magenetic sealed it will cause flickering, keep it away from monitor.
Otherwise your monitor need to be get service. So please contact your manufacturer service centre.
Thanks
Iqbal
Mar 30, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
1,333 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
