Random disconnections, DNS/key port failure
I'm using an eHome wireless router from my internet, and randomly my internet connections uts out for anywhere from 2-10 minutes at a time. The MSN messenger troubleshooter says that there's a problem resolving the DNS and a problem with the key ports as well. Every time i try to access the router by its IP address, the disconnect occurs as well. Getting it to work again seems to be completely random. A solution would be very much appreciated.
  • 2 more comments
  • c_drouillard Apr 29, 2010
    Well define what you mean by old. If you mean used a lot, that's not the case, as I actually just got this thing out of the box to replace my older router quite recently. As for the model itself, I'm not sure how old it is, but these are the specs.
    Brand Name
    D-Link
    Product Name
    eHome EH-100 Wireless Router
    Product Features
    WEP
    Wireless B
    Wireless G
    Key Features
    Router Functionalities VPN Pass-Thru
    Connectivity Wireless
    Interfaces
    Built-In 4-port Built-In Switch
    LAN Interfaces 10/100 Base-T
    Standards and Protocols
    LAN Standards IEEE 802.3 CSMA/CD or Ethernet
    Protocols PPPoE
    Firewall / VPN
    Firewall Features Stateful Packet Inspection (SPI)
    VPN Protocols IPSec
    Authentication RADIUS
    Wireless
    WLAN Standards IEEE 802.11g/b
    802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
    802.11g Data Rates 54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 28 Mbps, 12 Mbps, 9 Mbps, 6 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
    Modulation OFDM
    Security WEP
    WEP Encryption Length 40 bit (=64 bit)
    Antenna Type External Antenna x 2
    Miscellaneous
    Product ID 35359704
    UPC 790069292637
    Product MPN
    MPN DIR-625
    And of course the message submission ripped all formatting out of that making it nearly impossible to read.
    http://www.viewpoints.com/D-Link-eHome-E...
    Yeah it's looking like the router is just failing. I just don't understand why it would have problems without ever being used! Do they use radioactive materials that decay even when not in use to build them or something? Ah well. Looks like i'm going to have to start saving up for a new one.
  • c_drouillard Apr 30, 2010
    New information in, don't know if this changes anything, but when I try to access the router by putting the IP into the URL bar, it causes the connection to fail 100% of the time, and it DOES fail on wired as well.
  • 1,606 Answers
I would guess from your desciption that the router is around 2 years old. What you are seeing are typical for a failing home router. There are a few things you can try such as installing updates but generally those won't help for long. I've tried several things but in the end I ended up replacing it with a new one, That is what I would reccomend doing.
Posted on Apr 28, 2010
Testimonial: "Managed to pinpoint the approximate age just by hearing the symptoms, pretty impressive."
  • 1 more comment
  • Dave King
    Dave King Apr 29, 2010
    Old for a home router seems to start about 30 seconds after the warrenty ends. They are pretty reliable up to that point. Usually you see these symptoms on routers older than a year old. They are the typical failure pattern.
    Having said that and looking at my first response I am missing the part about checking the router verse the net connection or cable modem.
    Here is how you can narrow it down to what is causing the probem.
    Plug into the router using the wired connection. If the router is now stable then the problem is definitly the wifi section of the router. If it still disconnects then we want to rule out your cable or dsl connection. So now plug the wire/cable direct into the wan port of the modem. If you still see the disconnects the problem is the cable or dsl modem or something downstream with your isp. At this point you need to talk to them about replacing the modem or getting your cable fixed.
    Those symptoms are typical of the wifi section having problems and can occur on brand new ones. They usually don't quit totally they have this failure pattern of internittant disconnects that become more frequent before the wifi fails. The test will confirm where the problem lies.
  • Dave King
    The wired part should still work for a while. So you can use that at least. The wifi will just keep getting worse.
    I have a stack of dead wifi's all had failed the same way. Rather annoying and expensive. The ones that seem to last the longest are d-links and netgears. Stay away from linksys.
  • Dave King
    Dave King Apr 30, 2010
    That really sounds like a old tired one not one new out of the box.This wasn't a refurbished or previouslly opened I would hope.Either that or it was really made on a Friday about 2 minutes before quitting time. This one does have me curious.
    Just out of curiousity could try a hard reset. I don't think it will have a long term permanent effect. It may make it behave for a little while though. If that is the Dlink Ehome (There is a chinese knock off brand same name) then just push and hold the reset button for about 20 seconds. That restores the settings to factory. If it does anything it may be stable for a few weeks at most then will start the disconnects again. It won't be reliable for long if at all.
    I really don't know why the wifi routers all suffer from this. I've spent more than a little time with one companies support engineers (not the support twinkies who read from the script pages, these are the guys who design them) trying to sort this out on one model. Between us all we may have spent a few thousand dollars worth of labor trying to figure out how to fix a $40 router. In the end nothing worked.
DNS lookup fail at random times
I can suggest you a solution. I am not sure whether it will work or not but you can try this and see if that works.
Open the setup page of Linksys router using 192.168.1.1.
On the setup page you will see Static DNS 1. Enter 4.2.2.2 in Static DNS1. And Enter 4.2.2.3 in static DNS 2 option. Save the settings.
See if this works.
Also make sure that firmware on your router is upgraded.
Jun 05, 2012 | Cisco Linksys Wireless N Home Router...
Error code 52130, trying to hook up to the wireless internet. Any Suggestions?
Error Code: 52130 The Wii is unable to connect to the Internet
Likely cause: The wireless router is incorrectly connected, or the Wii console will need a DNS manually entered.
How to fix: Check the way your router is connected; manually assign a DNS to the Wii.
  1. Check the connections to your wireless router:
      Even if you are able to get a working Internet connection to your computer through the wireless router, if it is not properly connected to the modem, the Wii and other devices may not be able to use it.
    • Most routers have five (5) ports on the back. Typically there is a set of four, with a single port either farther away from the rest, or separated with a different color border or line. This single port is often labeled "Internet" or "INT." Make sure the cable coming out of your modem is plugged directly into this "Internet" port, and not into one of the other four that are grouped together.
  2. Manually change your Wii console's DNS settings. To do this, follow these steps:
    1. Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
    2. Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
    3. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
    4. Select "No," and choose "Advanced Settings."
    5. Click into the "Primary DNS" field and enter: 8.8.8.8
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4 Select "Confirm," and then "Save."
    7. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
  3. If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
Nov 26, 2011 | Nintendo Wii Console
Hello I have a type of router 802.11g 2.4ghz Dlink I want to learn how to work PASSWORD of the Internet in the home, so do I prevent neighbors from accessing the website of our own
In your router configuration, activate WPA2 encryption with a 64 bit key. Get a random key here:
http://www.grc.com/passwords.htm
Use this key to use the router connection with other computers in your home.
Sep 12, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Have netflix hooked up to wii, have code 52130 what does this mean
Error Code: 52130 Was this information helpful?The Wii is unable to connect to the Internet
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    7. Select "Confirm," and then "Save."
    8. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
Sep 12, 2011 | Nintendo Video Game Consoles & Games
Using wireless internet with the d-link router from virgin, keeps disconnecting randomly few times a day, still connected to the network, just internet cuts out, it comes back after 60 seconds or so,...
Sure. I'll assume you have Windoze....Winders.... XP Home or Pro.
1. Disable 802.1x.
2. Disable the "power save" feature on your unspecified wireless
router.
3. Disable Super-G Turbo mode if necessary.
Nov 26, 2009 | D-Link Computers & Internet
Ip address,subnetmask,primary dns,secondary dns,default router,
they should be given by the internet provider or you can try the following:
on a computer connected to the internet..go to the run menu(windows key and r key)
type cmd
a command prompt will open
in that type ipconfig/all
hope it helps!
Nov 29, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Laptop won't connect to wireless
Hello :-)
Try going into device manager, and uninstalling your wireless network adapter.
Reboot your PC. It will automatically reinstall your wireless network card.
Now try your wireless connection. This often solves random wireless issues.
Jul 08, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Mar 06, 2008 | 2wire 1800HG Router (RG1800HG00)
Wireless connection
You must obtain/set up one.
1. hook up a computer to one of the numbered ports on the back(eTHERNET CABLE. Like a phone jack but longer.)
2. wait untill the computer says it is connected.
3. open your internet browser, and go to this address: http://192.168.1.1(the routers internal setup)
4. type in "admin" in both boxes.(if you havent set up a password yet)
5. go to "wireless", "Wireless Security"(bar below first one), either choose DISABLED(you will not be protected from strangers accessing your internet, slowing yours down) or one of the choices and type anything in(recommend 15+ characters, better yet random. WRITE THIS DOWN.)
6. Click save changes
7. Go on your wireless enabled computer, and if you used a key, enter it, otherwise it should connect
Feb 21, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
651 people viewed this question
David Payne
David Payne
