Question about Philips Brilliance 150P Monitor
Images are not clear and it looks like a tv channel not tuned.SHH
Images are not clear and it looks like a tv channel which has not been tuned properly. that kind of rough images. how can i solve this
  • 61 Answers
W/power off
Try moving cables to another location and ckn connections
Posted on Apr 30, 2010
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Sony Trinitron KV-27TW77 will not change channels after setting up auto program. Remote or TV will not change channels.
You have not cleared the number of programs tuned in the auto mode,if only one program is tuned than only remote or TV will will not change channels,check by tuning with cable connection with multiple programs,you will get the solution.
Feb 06, 2011 | Sony Televison & Video
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
Can not tune the tv
My dear friend. A TV is a TV and TV's are many and varied. If you stated the model and what it exactly does, maybe I or other people could help you instantly. But since you have said little in relation to TV tuning, then expect a few guys to help you. But allow me to give you a hint that applies to almost all flat panel TV's, ok? Right. On every TV there is a MENU that gives you many options. First you need to press a button on the remote that displays component connection channels and TVincoming signal type. Since I don't know what brand of flat panel TV you have, I can only ask you to find and press the button on the remote that displays on TV screen the following component channels, that is DVT, AVT, Component 1, Component 2, HDTV1, HDTV 2, HDTV 3 and so on. Apart from DTV and ATV, from Component 1 to HDTV 3, these additional channels are for DVD players that also have HDTV outputs and BlueRay players and or Audio devices. If yout TV hasn't got as many channel input, then ignore this part. To tune your TV you have to first press the butoon on the remote to activate the onscreen channel as above, then scroll on DTV or ATV and, depending on whether you have Digital TV in your country or the standard high resolution Analog TV. Lets say you have Digital NTSC format TV system, select it and then press ENTER on your remote. In the menu you find and click SCAN. Depending on where you are, the TV will begin scanning all frequencies in your territory and possible interstates if the modulator is powerful enough to pick up weak signals. Most TV's have an inbuilt set-top box that boost the signal to give you a crystal clear pic. Now, after pressing SCAN, the TV reaches a signal with a clear pic, all you have to do is recognise the channel that comes in view. The instructions on how to save that channel are on screen and then you can configure it as, say channel 4, if the channel that appeared is channel 4, if not, try and recognise what channel had appeared and then configure it with a number, so when you press that number on the remote it will be the same channel you had stored in the TV memory. After you have done this, press scan again and it will scan to the next channel. Once the scanning recognises another clear signal and it is as clear as a baby's face, you have recognised the new channel. Try, find out what channel it is by looking at the screen, there is usually a visible TV station name or number embossed on the lower corner of the screen, once you know what station that is or what channel number it is, configure that number and press ENTER (save) button. Do the same with the remaining channels. Later I will tell you how to skip unwanted blank channels that usually have no signals but snow and lines, or have faint signals that can only be boosted with a TV booster available from reputable TV retailers, or install a bigger more powerful antenna.
Reagards.
Mike
Oct 06, 2009 | Televison & Video
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Sep 03, 2007 | Toshiba 30HF83 30" TV
Snowy picture and Yellowy Whites
Make sure the TV setting is set to or . A power surge may have reset your ?cable-ready? TV. Check the cable setting on your TV and make sure it is set to or . If a VCR is connected: * The VCR needs to be on channel 4. * VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. If a converter is connected: * Make sure the TV is on channel 4. * TV may not be ?fine-tuned? to channel Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * Determine if the converter is bad. Locate the cable wire coming in to the room and connect it directly to the back of the TV. If the picture is clear, your converter needs to be exchanged. Give us a call or stop by your local office and we?ll switch out your equipment. Check the fine-tuning of your TV
Jan 11, 2006 | Fujitsu Plasmavision P42VCA30EH 42 in....
Philips Brilliance 150P Monitor Logo
207 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
