Question about Coby DVD-937 5.1 Channel DVD Player/Receiver Home Theater Speaker System System
When i turn computer on it says unsupported mode: h:64 4khz, v: 60 2hz
  • Coby Master
  • 3,866 Answers
H: means horizontal at 644 H and V 602 is vertical measurements seems there may be something wroung with the video card resolutions or the display itself. This would need to be look at locally to determine what is causing this error. Seems like video to me.
please leave any comments or questions otherwise please do leave a postive rating and feedback, thanks
Posted on Apr 28, 2010
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Scenes are recorded in a unsupported mode for backup
how can i playback my videos if it comes up with unsupported scene, it has a blue box with a white question mark in it and i cant play it back
Jan 02, 2013 | JVC GZ-HM445 HD EVERIO PAL CAMCORDER
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
Screen says unsupported mode
what do i do when my insignia flat-screen says unsupported mode on it?
Dec 21, 2010 | Insignia NS-LTDVD19-09 LCD TV
Says unsupported mode.. what do i do to fix it
Mode unsupported error message usually appears when having problem sending a fax to a specific fax machine. Here's a link to the Lexmark website to guide you on what to do. http://bit.ly/alsndu. Follow the instructions carefully. Hope this helps. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jun 27, 2010 | Lexmark X4270 All-In-One InkJet Printer
I can not play my PS3 on HDMI "unsupported mode".
While turning the PS3 on from standby, hold down the power button until the unit beeps twice (it'll beep once right away, and again maybe 5-10 seconds later). That should reset the video output of the unit back to default, and you can go from there picking supported resolutions.
Jan 10, 2010 | Insignia NS-LTDVD19-09 LCD TV
Unsupported Video Configuration Detected
Apparently you set a video resolution which your monitor isn't able to handle. Try booting in safe mode by holding the F8 key at boot, then change resolution to something safe such as 1024x768. Reboot in normal mode and set the resolution you're most comfortable with.
Oct 29, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Vista driver for canon cp 300 printer
if Vista and 7 is unsupported by the printer manufacturer, you are pretty much out of luck. If Vista and 7 say the printer is unsupported or un certified, run the manufacturer software if you want.
You doult run in emulate mode ... but for as cheap as printers are these days, why would you want to run in that mode?
Oct 09, 2009 | Canon CP-330 Thermal Photo Printer
COPIER MODE IS NOT WORKING
Try turning the unit off completely to reset it first, especially if it used to copy and now will not.
Sep 15, 2007 | Lexmark X4270 All-In-One InkJet Printer
82 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
