Question about MSI PM8M-V Motherboard
I cant install windows in sata hdd for msi pm8m-v
    Scholar:
  • 77 Answers
Thank you for your question.
In this case, my opinion would be that the SATA Driver needs to be installed from floppy disc before the install of Windows. It is at the beginning of setup at the bottom of the screen in black writing on a grey background for Windows XP. It says "Press F6 if you need to install other drivers". This is your cue to press F6, the install will load drivers from there to enable the SATA on your motherboard.
If you do not have the motherboard discs, I have attached the link to the makers download page for your motherboard, you can obtain the SATA driver from here.
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=205
Good luck with your install.
Kind regards
Posted on Apr 28, 2010
MSI PM8M-V motherboard booting problem
I had a similar problem, not sure if same. my solution was (sata connector had broken solder joint. once fixed i was able to start computer no problem s afterwards
Mar 27, 2012 | MSI PM8M-V Motherboard
I cant install the video controller driver for my pm8m-v. it prompts an error saying that it cant be install. see the windows log for more info. pls help
You may have installed the wrong video driver.
You can download the drivers from MSI WEB support site,select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Dec 12, 2010 | MSI PM8M-V Motherboard
I have hdd sata and i want to setup win xp on it but i cant winxp can not cont
Check your BIOS setup for the SATA interface settings. If it's set to "Native" or something to that effect, change it to "Compatible" or "IDE" or similar, and try installing XP again.
As a last resort, you may need to supply SATA drivers for your motherboard (unpacked, with all the individual files visible) during the setup, when it says something like "press [something] to supply 3rd party device driver". The problem is, that Windows expects it on a diskette...
Jul 02, 2010 | MSI PM8M-V Motherboard
The Bios of MSI PM8M can not recognize SATA HDD. Please tell me how I can make this Bios recognize SATA.
You must check if SATA is enable in your BIOS. Sometime there is jumper which prevent this.
Jan 16, 2010 | MSI PM8M-V Motherboard
My sister has this bundled computer using a msi pm8m-v-7104 MB version 1.0. It has a sata HD in it but I don't see it in the bios and when I try to reinstall windows xp it says it cant find a hd to install...
HI t_hammer2003.
FIrst off, make sure that the sata cable is firmly seated on the drive and the board. When you turn on the computer listen for the drive to spin up. If you don't hear the drive try another sata port, and listen again. If they doesn't spin up, try another sata cable, listen for spin up again. If you don't get the drive to spin up, then you most likely have a bad drive.
There is one more thing you can do each time you are listening for spin up, is when the computer boots to bios, each time, you can go into bios and manually force the information from the drive to Bios. Sometimes Bios isn't always the most stable, especially since that board is rather dated.
Last effort would be to go and try another drive that you know works, and get the board to boot to dos, and upgrade the bios, it could be that they have never been updataed to patch some of the bios error handling sata hard drives. You can get those on the MSI website.
Good Luck
Mark
Dec 12, 2009 | MSI PM8M-V Motherboard
Hi There , I Bought a PM8M-V Motherboard cause my old mb died , aand im having problems with this! Intel(R) Pentium(R) 4 CPU 2.40GHz MB ID - P4M800-8237-6A7L6009C-00 MSI PM8M-V H (MS-7104 v2) 512 MB PC3200...
When it gets slow, start the Windows Task Manager.
Click the "Performance" tab.
Check what percentage of the CPU--power is being used.
Check what percentage of the RAM is being used.
Click the "Processes" tab.
Click the 'CPU' column-heading *TWICE* to sort the processes,
so that the "big" users of CPU are listed at the top.
Scan for computer-viruses.
Oct 29, 2009 | MSI PM8M-V Motherboard
I am not having vga driver
Hi sajal12,
http://www.driverstock.com/MSI-PM8M-V-driver-download/14-9-11370/index.html
Here you will find all the drivers for MSI PM8M-V Motherboard like display , SATA driver, video driver, audio driver, chipset driver etc
Best of Luck and dont forget to Rate :-)
Jun 03, 2008 | MSI PM8M-V Motherboard
Msi pm8m-v series micro-atx mainboard is not detecting 160gb seagate sata harddrive
Had u properly connected the driver to motherboard..?
U can change the sata cable. Check the power connection also.
Jan 19, 2008 | MSI PM8M-V Motherboard
MSI PM8M-V Motherboard Logo
439 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
