I need to know what the transformer looks like and where it can be found at on the board for my panasonic PT-47WX51E TV
  • pbarnett2003 Apr 28, 2010
    ok i am not sure which one it is my tv will start to come on then cuts off when the lights for the pitcher starts to light up. then you have to un plug it to try it again but it will do the same when you plug it back up and turn it back on.
    thank you
  • 4,889 Answers
What transformer is it that you are looking for? Is it the flyback or the ordinary transformer?
The flyback looks like this
http://www.cinelabs.com/amp/amp-fb_v2_crop_sm.jpg
The regular transformer looks like this
http://www.electro-tech-online.com/attachments/general-electronics-chat/29570d1243209826-basic-transformer-use-power-supply-circuits-7-pin.jpg
Warning: Be advised that the flyback transformer holds 1000's of volts so does the anode cap where the transformer is plugged in. You should discharge the voltages before you attempt any repairs.
Sai.
Posted on Apr 28, 2010
  • eagle338
    eagle338 Apr 28, 2010
    It does not sound like a transformer issue but rather a power supply board issue. However I did not understand what you meant by "lights for the pitcher". Also do you hear a clicking noise from the set before it turns off?
Panasonic tv PT-47WX51E has green vertical lines,how do I get them out?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Jul 27, 2015 | Panasonic Televison & Video
Panasonic pt53wx53 led blinks once
unplug the set---where smoke something has burned.
I would with back off have a look---look at high voltage transformer and that area of board and pay special attention to C509 (brown cap in front of high voltage transformer about 2 inches---it will be marked with that C509 on board.
If it is cracked or burnt it is bad---these fail a lot.
If the set needs to be worked on it has a lightbox---about 8 bolts removed and entire guts or chassis comes out in one piece--can be powered up out of the cabinet.
Let me know if need more information.
May 29, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-47wx53 C509
As you look from the back of the set (with the cover off) it is on the far right large board, C509 is the location number--it will be printed on top of the board under the cap.
It is about 2 o'clock near a large plug--on right side of right board--the one with the large gray transformer with a large red wire--part is forward of that transformer and red looking in color--two leads---it will have the C509 printed on top of the board under it.
This is a common failure part is this set--some will have a physical crack in the red part and others will look perfect-----value with a cap checker is .47 UF----200v is the working voltage --as long as you replace it with a cap of at least 200 volts of the same value--it will be fine--
There are two ways to get at it--pull the large board it is on OUT--I do not recommend this----or pull the whole light box out---very easy and safe---if you locate the cap and want to know how to pull the light box out let me know--
If this has helped you rate this solution as I do this here for free.
SD TECH
Jan 05, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Can a blu ray dvd work with a panasonic pt-47wx51e?
Yes, you will need to hook it up just like a normal DVD.
If you can use the component inputs you will get a better picture.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 28, 2009 | Panasonic PT-47WX51 47" Rear Projection...
My panasonic tv pt-47wx51e color looks like 3d how can i fix this
There is a convergence kit available for your model which contains the new ICs and resistors plus the instructions of how to install the repair kit on CD. Heres a link look under Panasonic repair kits and you will see your model listed.
www.tvrepairkits.net
Jun 26, 2009 | Panasonic PT-47WX51 47" Rear Projection...
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Screen went black Panasonic TV/ PT-47WX53
Hello twisttolife,
What you have lost is horizontal deflection, this is caused by loss of the horizontal drive signal to the yoke transformers on the CRTs, for all three of these to fail at the same time is not likely so what I think is that the drive amplifier may have malfunctioned. To check this you will need:
1) schematic diagram or service manual (to determine the proper voltages and signals on the deflection board)
2) Multimeter (to measure the DC voltages on the components of the deflection board
3) Oscilloscope (to view the waveforms on the deflection board)
With these three pieces of test equipment you should be able to troubleshoot this problem.
Now if you do not have this equipment and what to take a chance at a blind guess, and just replace a board, I would suggest replacing the deflection board, this board usually contains the flyback transformer, the Convergence modules (which can cause this problem also), and the connections to the yoke transformers.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Replace conversion board
Signal / Main PC board AKA the "A" board is send for repair only = PTS corp ....Part # TNPH 0370.....250.00 Approx.
OR
Replace IC7001 & 7002....STK392-110 and inspect resistors.
If you have good electronic repair skills,you might attempt to
DIY...otherwise, hire a senior tech,if possible...............T.
Feb 06, 2008 | Televison & Video
Where the wire goes
Try looking on the focus block in the front of the set. Take off the speaker grill, take the screws off the "wood door" and you will see the focus block on the front with six controls on it. Of course make sure the set is unplugged before sticking your hand inside the set. Leadtech
Dec 11, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
