Question about Sorelle Vicki
I connect mp3 player to my computer then one message ''your hardware not work properly'' give me solution my os is xpsp3
  • 3,866 Answers
Okay in most cases what you got here is one of the following:
1. bad cable
2. bad usb connector inside the unit itself
3. or a bricked unit.
most of these units die when a person just unplugs them from the computer without using the safly remove device icon on the task bar more often then not that is what happend with you. Now if that is what happend there is not turning back (no fix) sorry to bring the bad news. but check the cables first and check what I told you. let me know otherwise.
Please do not hate and leave a rate to be considerate! please leave some feedback aswell
Posted on Apr 28, 2010
Sony nwz-b142 doesn't display in my computer. I already tried installing the device in the control panel and it says device works properly and yet it doesn't display in my computer
This advice could help you if your player works properly and the problem is in your pc only:
At first you should be sure that your USB cable can work.
Then let's see the PC.
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
gylacz
May 03, 2011 | Sony Walkman NWZ-B142 MP3 Player
Cant open as a storage device on the pc
1 First connect it with ur PC with the data cable provided along with it.
Go to the My computer icon. right click on it. Select manage. one window will pop up select device manger and the in the right side a window will come . select the option of USB. The port with which ur hardware is connected will show with yellow error mesage. slect that port and unistall the driver and select the main menu of the USB and select the option scan for the hardware changes.
2 If it detects ur hardware device then ur device is ok no physical damage.
3 Reinstall the OS with the help of the CD provided along with this player
4 Read the manual carefully before installing the OS.
Please note that never format the MP3 player while installing the Os the manual caonatins step by step procedure to install the OS follow that only.
If you format the MP3 player then ur Mp3 player willl be permannetly damaged.
Jan 26, 2011 | Sony Walkman NWZ-B142 MP3 Player
This thing does not work always says ok to disconnect
When the mp3 player is connected to the computer, the only message it will generally give you is "OK to Disconnect" - this is normal.
Once you disconnect the mp3 player from the computer, then you can find your music, listen to music, etc.
If you are getting the "OK to Disconnect" message when the mp3 player is already disconnected from the computer:
Reset the player first.
If that fails:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Feb 28, 2009 | Philips SA3025/37 Flash MP3 Player
Setting up my zune with my pc
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Mp3 not working properly
Try connecting it to the computer then fomating it. so it starts all over.. it should work
Jan 15, 2008 | RCA H100 MP3 Player
Red ilo
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Nov 06, 2007 | iLO (2 GB) MP3 Player
HDD read error
I had the same problem with my mp3 player. The problem seems to be that the charge had been depleted - even though the screen said the charging was complete when I plugged it in. Disregard the screen, charge your machine for two hours, and if your player is like mine, it will be functioning properly afterwards. Hope that helps.
Aug 15, 2007 | Coby MP-C941 MP3 Player
Sorelle Vicki Logo
32 people viewed this question
Top Sorelle Baby Gear Experts
Jeff Turcotte
Jeff Turcotte
Brett Duxbury
Brett Duxbury
Tom Chichester
Are you a Sorelle Baby Gear Expert? Answer questions, earn points and help others
