Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
MAXTOR Personal Storage 3200 - LED light rapid blinking
'Would like to ask help in determining the problem of my unit which was previously working but now when I plugged the power, the LED just blinks rapidly and the drive does not show up on my computer.
Please advise what's probable cause of this problem and any possible solution.
Thanks and regards,
robert
  • 3,866 Answers
Many experts beleave you got a bad AC adaptor the plugs into the wall. My findings are the following.
If you hear the drive spin up but does not show up on your computer then you got a bad controller board inside the case of that hard drive. The fix take the drive out of the enclosure and put it into another enclosure or simply install it into your computer.
I have videos on a WD mybook witch is not the same model or manufacture but still helps some people figure out what to do. Please be considerate i mean the videos are dark but you can still make out on whats going on.
http://www.fixya.com/support/r3574054-external_usb_hard_drive_data_recovery
Now you can try a AC adpator for this unit some ac adaptors do fail but in most cases its the little usb to sata connector inside.
good luck with this and please do be considerate and rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 28, 2010
Maxtor Personal Storage 3200 500 GB Hard Drive suddenly not recognized. Light on, tried alternate similar power supply, tried different computer along with different operating system. Please help.
May be your Personal Storage 3200 500 GB Hard Drive power socket pins are not seated well when you connect so make sure the pins are in good condition.
Think this is helpful !
Aug 11, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
Try connecting the Maxtor to another computer and if it functions normally, then backup your data. Then try formating the Maxtor on your computer.
Sep 08, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Computer does not recognise the Maxtor 3200 personal storage
hdd problem,, 50% can fix you hdd.. if you have inportant data just make recover.. you can't use that for install program and operating system just only for external, save data but dangeros also maybe someday it wil not work totaly..
try to change the board if could
Jun 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200 light is blinking. The computer won't recognize it so that I can access my files. Howerver, if I unplug it from the computer, the computer dings like it knows something was there. This is...
I've had two of these Maxtor Personal Storage 3200 drives and both have failed. On the first one, one of the Best Buy Geek Squad guys told me the card (circuit board) was bad. I bought the exact model, swapped cards and the old drive worked fine... for a while. Now it has died. So I am online looking for another one, so I can swap cards again to rescue my data & photos. NAS home server with RAID is my next step. Buffalo is the brand I am looking at...
Jun 06, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor external Hard drive not recognised on any pc
Hi cimbom76,
Sorry to hear of your problems. The following is taken from the Seagate (they own Maxtor) website at :-
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&thread.id=192
For Maxtor Basics and Personal Storage 3100 and 3200 drives, there may or may not be an LED on the power supply, but the light on the drive should usually remain solid during normal operation, while powered on.
1. But if the power supply does have an LED on it, isolate the problem by connecting the power supply into a power outlet without the hard drive connected to it. If the LED blinks in this configuration, the power supply is faulty. Please contact Technical Support for replacement information.
2. If the LED remains solid, connect the drive. Once it is connected, turn the drive on. If the LED begins blinking, the drive has an electronic failure. Please replace the drive. You can create a warranty replacement order to replace the unit.
From what you have said i'm afraid it sounds like there is an electronic failure of the drive. I haven't followed the process through but they do offer a Data Recovery Service at :-
https://services.seagate.com/index.aspx?lng=en-us
There is an online form to fill in or you can telephone
020 7432 4619 to talk to a Data Recovery specialist.
I hope this helps and I hope that you can recover your pictures and videos.
Mark.
Apr 12, 2009 | Maxtor Basics Personal Storage 3200 Hard...
My Maxtor 3200
what was the voltage difference between the supplied adaptor and the one you plugged in by mistake ?
Robert
Dec 17, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
There is a troubleshooter that describes steps for these symptoms on Seagates Knowledge Base website.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=188697
Aug 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage Unit 3200 - Model U01E100
it makes no difference how old the drive is, unless you transfer the same amount of content everyday and can chart and predict. It  might help to wrap your mind around the actually capacity and extent of files you trasfer and use. If that drive is a 200GB....1 gigabyte is roughly 1 cd and a half. A compact disc can hold 700MB, or gauge it to like a ipod.  So if youre possibly transferring say 2GB per day, you will reach the max of the drive in 3 months?
2GB X 90 days=180GB
If you are using graphic applications, or video...you may want to look towards a 320 GB or 500GB as things only get larger with current computers........Just 3 years ago, who knew what a gigabyte was? Now we own drive in upwards to 1TB ( terabyte ).
keep me posted..
Oct 24, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
368 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
