Question about HP Pavilion F1523 15" LCD Monitor
When the monitor is switched on an orange light shows, no green light and screen says 'going to sleep'
  • 560 Answers
Your computer is not able to "see" the monitor. Try going into the BIOS settings when u first turn on the computer by pressing F1 or whatever key your computer uses to enter "SET UP". Then, select the F key that will "load default settings". Then, press F10 to "save and exit" and press enter to confirm. If that doesn't work, you either have a bad/incompatable monitor or a problem with connections or the video card or port.
Posted on Apr 28, 2010
How to solve acer monitor sleeping issue?
Press left mouse key and wait 10-15 seconds. Black screen and orange light is caused by computer going to sleep. Adjust your power mode.
Apr 30, 2014 | Computers & Internet
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Apr 17, 2013 | HP 1502 LCD Monitor
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
What is the problem if the screen does not go on green and orange light goes on
Is it in sleep mode or hiberating mode? Green or orange lights on the top of the laptop for not fully charge battery or some signal lights for your brand of laptop? If the later, you can check the manual to see what those lights indicates. Otherwise, you may put on the power cord and press the power button to wake it up or restart it. Then set the preference for sleep mode or hiberating mode in control panel, power options. There also could be a hardware issue though. You may need to press on the position of the processor so it will sit firmly on the mainboard and if possible check the connection of cards and hard disks and memories and make sure they are well connected. If there is still an issue, you can try to flash the BIOS, reset the hard disk to factory default according to the manual or there might be an issue with the monitor. Try another monitor connected to the other VGA port of the laptop.
Sep 02, 2010 | Computers & Internet
Computer powers up but monitor goes right to sleep?
when i power start my computer,,the light come on and seems to operate but the monitor doesn't come on,,,when switichin the monitor off and on , the blue light comes on and it reads monitor goin to sleep and the screen gets dark,,but the monitor orange light is on,,,pls help
Sep 21, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor led light goes from green to orange will not respond
Your video card or on-board video is kaput. If it worked fine on the other system, but not working on this one ... then you've blow the video.
One note: When the computer is ON, do NOT unplug and re-plug in the monitor. You'll blow the video card.
Luckily, add-on video cards are cheap and readily available ...
Jun 12, 2009 | Compaq MV 540 15" CRT Monitor
Monitor keeps going i to sleep mode
Check the cable it's not connected correctly or check you CPU is it working fine.
Dec 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
Oct 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
HP Pavilion F1523 15" LCD Monitor Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
