Question about Cameras
Zoom goes in and out a couple times when I turn it on and then it stops and the display is blurry. I try to auto focus and nothing happens... Auto focus is on and I've changed the auto focus settings and still nothing. What can I do to fix this?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 28, 2010
When zoom in and out while on Auto Mode, the focus went off focus and took some time to adjust. How do I stop that from happening?
I would consider focus shift when zooming normal. Most small digital camera zoom lenses do that. If your auto-focus is slow, all I can suggest is patience or a newer/better camera.
Oct 30, 2014 | Cameras
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
While recording the Camcorder goes in and out of focus. If I keep the camcorder running and either zoom or pan out the subject refocuses, but if i hold at that level of focus the subject becomes blurry...
It sounds like you are either too close to the subject or you need to flip the focus switch to automatic.
The Auto/Manual focus button is located on the left side of the camcorder under the LCD monitor flap.
Other than that, does this happen only in low light? The camera will have trouble focusing in low light usually.
Mar 01, 2011 | Panasonic SDR-H40 HDD Camcorder
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
Focus and or Zoom problem
double check that its still in auto focus, i went a whole day trying to figure out why my camera wouldnt focus, and i had auto focus off
Jul 12, 2008 | JVC GR-D770 Camcorder
Auto focus
Make sure the macro funcion is off sometimes I forget to turn it off and when I try to take a normal picture it has a bad time focusing.
Jun 25, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Jun 22, 2008 | Nikon Coolpix 4300 Digital Camera
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
Palmcorder will not focus
you should changed the focus to manual state please try to see in the viewfinder , do you have the MF apears , try to enter the menu and change to auto focus state regards please don't forget to rate thx
May 01, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
