Question about Cameras
Zoom goes in and out a couple times when I turn it on and then it stops and the display is blurry. I try to auto focus and nothing happens... Auto focus is on and I've changed the auto focus settings and still nothing. What can I do to fix this?
  • curly_headed Apr 28, 2010
    Ok, even thought its bad news, im just glad i know what is wrong with it now. Thanks!
  • Cameras Master
  • 3,866 Answers
Your auto focus sensor is malfunctioned in saying this you going ot need repair this explains why the lens goes in and out like this its trying to focus but cannot find the point and this is cause by the auto focus sensor the has apparently malfunctioned the best course of action is repair locally for this camera.
I am only giving you the truth, I know its not what you want to hear, I wish there was more I can do for you at this point but the only thing we can suggest is repair at this time.
thanks and please be considerate and press the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 28, 2010
When zoom in and out while on Auto Mode, the focus went off focus and took some time to adjust. How do I stop that from happening?
I would consider focus shift when zooming normal. Most small digital camera zoom lenses do that. If your auto-focus is slow, all I can suggest is patience or a newer/better camera.
Oct 30, 2014 | Cameras
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
While recording the Camcorder goes in and out of focus. If I keep the camcorder running and either zoom or pan out the subject refocuses, but if i hold at that level of focus the subject becomes blurry...
It sounds like you are either too close to the subject or you need to flip the focus switch to automatic.
The Auto/Manual focus button is located on the left side of the camcorder under the LCD monitor flap.
Other than that, does this happen only in low light? The camera will have trouble focusing in low light usually.
Mar 01, 2011 | Panasonic SDR-H40 HDD Camcorder
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
Focus and or Zoom problem
double check that its still in auto focus, i went a whole day trying to figure out why my camera wouldnt focus, and i had auto focus off
Jul 12, 2008 | JVC GR-D770 Camcorder
Auto focus
Make sure the macro funcion is off sometimes I forget to turn it off and when I try to take a normal picture it has a bad time focusing.
Jun 25, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Jun 22, 2008 | Nikon Coolpix 4300 Digital Camera
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
Palmcorder will not focus
you should changed the focus to manual state please try to see in the viewfinder , do you have the MF apears , try to enter the menu and change to auto focus state regards please don't forget to rate thx
May 01, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
