I would like to know if i can add to my panasonic PT-47WX51E so that i can hook up my pc to it for a pc screen.
  • pbarnett2003 Apr 28, 2010
    yes that is what i need to know thank you for your help.
  • 12,061 Answers
Http://service.us.panasonic.com/OPERMANPDF/PT47WX49E.PDF
Above is a user manual, shows you how to hook up. YES you can. Use the links below to help you set up multiple desktops. Basically, You must Hook Up to the OFF TV, then start up PC, Turn ON TV, then setup according to instructions, and extend your desktop, Also set to a lower resolution to start with, say try 800x600, then if your set is able you can increase it.
Below are the setup links for multiple desktops.
http://www.microsoft.com/windowsxp/using/setup/learnmore/northrup_multimon.mspx
www.microsoft.com › ... › Computer Setup and Maintenance
Posted on Apr 28, 2010
Panasonic tv PT-47WX51E has green vertical lines,how do I get them out?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Jul 27, 2015 | Panasonic Televison & Video
My aspect will not work on my panasonic pt-50lc13
The DirecTV box controlling it automatically? If not it might be some crud under the button on the remote that needs cleaning up.
Use Isopropanol alcohol to clean up the contacts if this is the case
Jul 25, 2014 | Panasonic PT-50LC13 Television
Colour spots on pt-61lcx65-k panasonic tv
Need to have a service tech come out and calibrate the TV. I had spots on my screen and the tech came out and hooked his computer up and calibrated it and it worked fine afterward.
Feb 24, 2013 | Panasonic PT-61LCX65 61" Rear Projection...
Can a blu ray dvd work with a panasonic pt-47wx51e?
Yes, you will need to hook it up just like a normal DVD.
If you can use the component inputs you will get a better picture.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 28, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic tv pt-47wx51e color looks like 3d how can i fix this
There is a convergence kit available for your model which contains the new ICs and resistors plus the instructions of how to install the repair kit on CD. Heres a link look under Panasonic repair kits and you will see your model listed.
www.tvrepairkits.net
Jun 26, 2009 | Panasonic PT-47WX51 47" Rear Projection...
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Replace conversion board
Signal / Main PC board AKA the "A" board is send for repair only = PTS corp ....Part # TNPH 0370.....250.00 Approx.
OR
Replace IC7001 & 7002....STK392-110 and inspect resistors.
If you have good electronic repair skills,you might attempt to
DIY...otherwise, hire a senior tech,if possible...............T.
Feb 06, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
