I have a panasonic PT-47WX51E that i changed the IC's in and now it starts to come on then cuts off and you have to unplug it and plug it back up to turn it on again but as soon as it lights up to come on it will click off again.
  • pbarnett2003 Apr 28, 2010
    thank you! This site has been a great help to me.
    what does the transformer look like and where can it be found at on the board.
  • 712 Answers
Now it is not your I. C. It is the t.v transformer, a small device which can go faulty due to frequent or high voltage fluctuations or lightnings etc. All you have to do is replace that simple and cheap instrument which is readily available in the market. Always go for the best one as there are some duplicates in these section which may run out soon.
Posted on Apr 28, 2010
Panasonic tv PT-47WX51E has green vertical lines,how do I get them out?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Jul 27, 2015 | Panasonic Televison & Video
I have installed a new lamp in my 52 inch panasonic hdtv and after just a minute the tv cuts off not sure why?
Hi
If the TV is working correctly during that minute then the shutdown circuit is sensing a component failure or mismatch. Did you plug the lamp, inverter, power supply back in correctly? What was the original symptom? Did the TV work OK for a minute and then after a minute go dark? If this were the case then the lamp may not have needed changing but rather a capacitor and/or IC overheating. Good luck
Apr 14, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Can a blu ray dvd work with a panasonic pt-47wx51e?
Yes, you will need to hook it up just like a normal DVD.
If you can use the component inputs you will get a better picture.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 28, 2009 | Panasonic PT-47WX51 47" Rear Projection...
My panasonic tv pt-47wx51e color looks like 3d how can i fix this
There is a convergence kit available for your model which contains the new ICs and resistors plus the instructions of how to install the repair kit on CD. Heres a link look under Panasonic repair kits and you will see your model listed.
www.tvrepairkits.net
Jun 26, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Projection HDTV won't power up, red LED flashes in front
i am having same problem. 3 flashes indicate convergence problem according to auto diagnostics that you are seeing(info from service manual).
i am starting by replacing stk392-110 convergence amp ic($6 at electronic.com). just ordered them, will let you know how it goes. please check this site-- http://biobug.org/ht/panasonic/ -- very good step-by-step on procedure.
will need service manual afterward. email me if you want copy.
good luck and godspeed,
bridgeman001
Apr 17, 2009 | Panasonic PT-53WX52 53" Rear Projection...
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic DLP PT-52DL52 Problem
your lamp is reaching the end of its usuable lifespan. Repalce the lamp that should solve your problem.
Mar 29, 2008 | Televison & Video
Pt-51hx41e panasonic tv power problem
CHECK VALUE OF LOW OHM RESISTORS, THEY SHOULD ALL BE EXALCTLY THE SAME.
Nov 26, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
