Question about Mitsubishi WS-65809 65" Rear Projection Television
Pinkish red screen
Just received a 60" rear projection mitsubishi tv. It's about 10 years old and I was told that the tv was fine. I turned it on and the screen has an extreme amount of pink, the picture is there, but seems like pink is everywhere. I tried changing the convergence and contrast but adjusting the color is not working, any ideas on why the screen would be giving this color or how to fix would be greatly appreciated. I also cleaned the inside already. Someone told me that there was a wheel that should be spinning on the inside when you turn the tv on and that the problem could be that the wheel isn't turning, but I can't seem to find a wheel?
  • Anonymous Jan 23, 2009
    I have an Infocus projector. When I turned it on for a presentation everything was red. We could see the pictures but background was red and the operator used all the adjustments. When we got it home it looked like it was o.k. but the next time I connected it and turned it on for a presentation it was red again. What do you think might be the problem. Jane Reese
  • Mitsubishi Master
  • 8,617 Answers
Your set doesnt have a color wheel you have 3 CRTs instead. Try turning down the red drive on the red crt circuit board that should help if not check the resistor that is connected to the red drive switch Vasriable resistor(switch) that is probably open if not the crt is probably at fault. If you need more info let me know.
Posted on Mar 24, 2008
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
May 10, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
237 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
