Question about Health & Beauty
Have a flat tire on a Chauffeur Scooter rear wheel.
I have a Chauffeur heavy duty scooter that is about 9 or 10 years old. The serial number is 00 60322. I removed the nut in the center of the wheel, then a inch long key wedge was removed that lays on a sleeve. The wheel stii doesn't want to come off. Do I need to disconnect the batteries? Are there brakes holding the wheel?
Thanks so much for any help you can offer.
I just removed the right rear wheel from my Chaffeur scooter. I first removed seat, plastic cover and batteries. Then removed wheel center bolt, set scooter on it\'s side and used a short 2x4 and rubber mallet to drive the wheel off. A shot of penetration oil helped. It is an extremely tight fit.Can\'t figure the two piece rim out though. Anyone have suggestions on why it is a two piece and how to remove tire from rim?
Posted on Oct 02, 2013
Benimur
  • 6966 Answers
SOURCE: Battery location on scooter
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, have to inform you, have not worked on one. Being in the Philippines most that I have laid my hands on are Japanese with a sprinkling of Italian but don't recall ever working on a French scooter. Sorry.
Still as you posted "Any advice...", allow me to do some guesstimate:
  • most scooters would have the battery located low;
  • would not be more than 50 cms away from the starter motor/engine;
  • being a 125 engine, battery would have to be about 7A/H, a bit heavy, therefore battery holder would not be on any of the plastics, chances are to the frame;
  • likely to be under the seat but there would be the helmet compartment, so maybe lower.
With the above assumptions:
  • either under the helmet compartment front of the engine (but would have an easy access panel/lid; or
  • under the footrest/floorboard.
Pls update how close or how far, curious myself. Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Posted on Dec 30, 2008
SOURCE: Cannot unfold our Bratz Musical Stars Fold Scooter
Call MGA toll free 1 800 222 4685 and they will walk you through the procedure. You have you put one hand on the slanted bar with the yellow label on it and one hand on the foot board and push in and down at the same time. Push at the same angle as the slanted bar. I couldn't get ours open either so I called the company - Good Luck!
Posted on Mar 19, 2009
SOURCE: 50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Posted on May 19, 2009
bunnydawg
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
gewiz
  • 1263 Answers
SOURCE: Need service manual or electrical wiring diagram.
one ofthe best ways to work it out is the find the motor controller, normally it's a black box located under the seat,
Now remember you have two wires from the batteries B+, B-, two wires to the motor, M+, M- and some smaller wires on maybe a ten connector block that leads to the tiller where the throttle on the handlebars is located.
Hope that helps
Regards
GeWiz.
Posted on Oct 02, 2009
Who make chauffer mobility power wheelchair
The Chauffeur Scooter Company bought up by Electric Mobility Corp(Rascal). So some consider it a Rascal. Some of Chairs were also made by Merits
Feb 28, 2015 | Electric Mobility Mobility Electric Power...
How do I put air in the tires?
It is possible that your scooter may have solid tires which means no air is required. You should be able to see a hole in the wheel rim where, if air tires were fitted, the valve would come out. No Valve=No Air. The rims are of the split type which you have to take the bolts out in the middle of the wheel to split the wheel to change the tires.
Jun 11, 2014 | Pride Mobility Products Maxima 3 Wheel...
Wheel hub
The hub may not accommodate the different tires.
Apr 10, 2014 | Electric Mobility Mobility Electric Power...
I need a scooter, and my father's 10-12 year old pride wrangler is in my mother's garage. Who can I take it to in my area to get new batteries and check out to get it ready to roll. I live in Claremont Ca....
gayree look up wheelchair and scooter repair on your computer they are located in the LA area but have techs all over Call 1-888-584-3095 to see if they can help hope this helps you
Apr 12, 2011 | Pride Mobility Products Wrangler 4 Wheel...
I have the exact same problem. This is a Fortress Scientific 2001LX C series. Not sure what exactly the free wheel lever is, but I'll assume that it's the lever that touches the tire? You can't budge this...
MaryJain The scooters freewheel lever should be at the right rear of the scooter under the shroud and no it shouldn'd be touching the tire. To put it freewheel you should push the lever down. Now if the lever is rubbing the tire you can try to get someone to push it sideways toward the left tire to get it away from the right tire. It should move easily into and out of gear. Be careful not to break it or the small micro switch on the brake. Hope this helps you
Oct 27, 2010 | Electric Mobility Mobility Electric Power...
Missing manual Do you know where I can get a manual for Freerider Kensington mobility scooter thanks Dianne
I need a manual and wiring diagram for a electric mobility mobility electric power scooter wheelchair model chauffeur 230
Jul 01, 2010 | Electric Mobility Mobility Electric Power...
My front tire keeps going flat do i need a new one, and if so where can i get one and what size do i need. It's a chauffeur mobility scooter.
This could be solved quite easily. Ask your local bicycle repair guy to give you a hand and repair the inner tube. I am sure that he will be delighted to assist you. Happy scooting. Regards Chris… info@mymobility.co.nz
Jun 19, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
243 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
