Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Can't seem to keep the black ink going!
I just put in another brand new ink cartridge and it worked great for the first dozen pages and then back to fade out and nothing, again. I've been having this problem for quite a while and have resorted to cleaning the inner head where the black ink cartridge goes with "Energine Spot Remover" and that always gets it to going again, but for only a little while. My husband is really beginning to curse the thing. We own a fairly new Kodak ESP 3 AI0 all in one printer. I was sold on the fact that it would save me on ink, but, this is a real problem!! Anyone else had this problem. Do we need to send it in for repairs or what????
Joyce from Kansas
  • 78 Answers
You can check advance settings oh print settings its printing with to much ink try to lower to a level the is visible and is going to last more
Posted on Apr 28, 2010
I refilled the black ink cartridge, and when I put it back in the printer, the printer says ERROR 13 meaning the ink level cannot be detected. Its essentially a brand new cartridge. What do I do? Ive tried...
It is not possible to refill the original Canon cartridges. The ink level indicator is integrated in the chip on the cartridge. When refilling, the information on the chip will not be changed and keeps giving the info that the cartridge is empty.
Apr 03, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
The colour ink cartridge is not being identified. I have tried taking them out and putting them in again. I have powered it off and on but nothing is working. Any suggestions would be greatly appreciated
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Jan 09, 2011 | Dell 924 All-in-One InkJet Printer
The black ink wont work, even though i have put in a brand new cartridge. the tri color works fine, but the black ink must have something funky going on
Try the following things:
  1. remove the cartridge make sure that you have removed any tape or guards that came with the cartridge to keep the ink from leaking
  2. try gently squeezing the cartridge. if you can get a drop to come out of the cartridge.
  3. if you cannot get a drop out, put the head of the cartridge on a piece of a dampened napkin or paper towel. You should see some black bleeding out of the head. Sometimes, it can take awhile for the ink to loosen up.
  4. reinstall the cartridge and run the head cleaning program for your printer if you have one
May 27, 2010 | Canon PIXMA iP90 Mobile Printer
MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Aug 05, 2009 | Brother MFC 490cw Color Inkjet...
Will not print text in documents, only headings.
When you go to print on your settings select print in black only. Did you buy Brother ink? Having old cartridges refilled or buying generic can pose a problem. I remember correctly brothers have a chip on the ink cartridge? I have gone through so many printers and its really not worth going any further, seems as though you have put sometime and effort in to this 100$ printer. Take 100$ & buy a kodak easy share all in one the ink is 15$ brand new.
Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
My cannon pixma mp800 does not recognize the cyan ink cartridge, which is brand new.
I had same problem with yellow ink cartridge. After going thru other suggestions I found on different forums that didn't work (turning printer off and on, cleaning contacts with alcohol, taking out and putting cartridge back in several times) I finally called Canon as my printer was still under 1yr warranty, and they sent me a brand new cartridge free of charge and it works great now (even though my cartridge that was giving error mssg was almost brand new too). I think they have a lot of lemon cartridges out there.
May 09, 2008 | Office Equipment & Supplies
Dell 924 printer problem with black cartridge
Dell printers donnot seem to work on refilled cartridges. Do buy new cartridges to fix the issue
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Printer will not work after installing a new cartridge (name brand)
I put the original almost empty cartridge in again and printed one page. Then I took it out and put in the new one, after wiping the contacts with a piece of plain paper. it worked!
Feb 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
HP PSC 1350v Check Print Cartridge Light
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge (office depot) I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 18, 2007 | HP PSC 1350 All-In-One Thermal Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
91 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
