Question about Brother LS2020 Sewing Machine
The needle does not clamp into the machine. - Brother LS2020 Sewing Machine
  • 560 Answers
Is it the first time you are going to use the machine?
can you notice any broken parts?
forgive me if I give you this note but I have no idea about the level of your knowledge on how to use the machine. this might help if its the first you are going to use a sewing machine:
loosen the screw that's holding the needle, insert the needle with the flat side of the needle facing the screw and the arc side is facing you then tighten the screw.
Posted on Apr 28, 2010
Twisted wire guide for the thread above the needle
Slide it onto the needle clamp from the bottom before you attach the needle clamp to the needle bar.
Mar 14, 2014 | Brother XL-5130 Mechanical Sewing Machine
How to fix needle on a machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
here's a link for a manual for the machine
http://www.sewingpartsonline.com/instruction-manual-euro-pro-9110.aspx
Aug 23, 2012 | Euro-Pro Shark 9110 Sewing Machine
Fixing a new needle on a sewing machine
Here's a tip
My singer 247 stopped picking up the bobbin thread.
rethread the machine top & bobbin
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw
if these suggestion don't help then the machine needs to be checked
to see if it's out of time
Jun 11, 2012 | Sewing Machines
BOBBIN THREAD BINDS UP AND JAMS MACHINE
check the thread take up lever to see if the thread has come off
that can cause the machine to jam
change the needle
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check the bobbin to make sure it's not warped
Jun 07, 2012 | Brother CE4000 Computerized Sewing Machine
Cannot catch bobbin thread
try rethreading the machine top & bobbin
make sure the bobbin is threaded correctly & inserted into the bobbin
case correctly
change the needle
if these suggestions don't help,, then the machine may need to have
the timing checked at a sewing machine shop
Jun 06, 2012 | Simplicity American Denim SA1100...
Zigzag stitch problems on brothers pc-420 sewing machine
Sewing machine skips stitches
1.needle inserted incorrectly
flat side of the needle faces the shaft
round needle
groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle.
Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
I have a BROTHER DISNEY pe770 EMBROIDERY MACHINE, THE THREAD IS BREAKING
Upper thread breaks--needle may be in backwards--
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
Mar 24, 2012 | Brother PE770 Computerized Sewing Machine
Needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Jan 30, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother LS2020 Sewing Machine Logo
23 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
