Question about Sony STR-DE698 Receiver
Protect Mode It goes to "protect" mode within seconds of being turned on..
  • 458 Answers
Need replaced power ouptup .assy
Posted on Apr 28, 2010
My hifonics bxi1210d amp goes to protect mode 2 seconds after turn on
Overdriving the output can cause it to go into protect mode. You will not be able to restore normal operation until failed components are replaced.
Jun 06, 2017 | Hifonics Car Audio & Video
I have Yamaha receiver and it shuts off after turning on within a second like it goes into standby mode. What could be wrong.
Your unit is going into protect mode. This normally indicates that you have a bad channel. Make sure that your speaker wires are not shorted or touching anything other than the turminal and check your speakers as well.
May 16, 2012 | Yamaha Audio Players & Recorders
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
The amp turns on but goes to protection mode
Have you checked the REM wire, if it is the wiring may have gotten fried.
Or you may need to get new parts replaced within the amp.
Both issues happened to me.
Mar 27, 2009 | Car Audio & Video
Amp comes on and goes right into protection mode
Turn the reciever on for a second or two and then off before the protect mode shows up on the monitor. Repeat this step about five times and check to see if the reciever does not go into protect mode. If it does go into protect mode try it again. Dont know if this is the proper way to fix the reciever but it worked for me. Good Luck
Mar 09, 2008 | Audio Players & Recorders
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Shuts off protect mode
i have a jvc stero and every time that i turn it on ...it show protect and shuts off!
Jun 25, 2007 | JVC HX-C6 Shelf System
Unit goes into protect mode
Not unless you know how to troubleshoot solid state electronics. If you disconnected the speakers and the unit still goes into the protect mode, most likely you have a short in one of the power output stages. Good Luck
Jun 03, 2007 | Marantz SR-4200 Receiver
Open Questions:
Sony STR-DE698 Receiver Logo
383 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
