Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Model X1 overheat
My X1 temperature reaches 120 dgs and "steams". The temperature reached light does come on and go off, hower it bursts steam into the cup via the coffee filter holder.
  • deedee754 Jan 17, 2009
    HELP - I can't figure out how to take the steam knob off my ffx1 so i can fully remove the top. any help would be greatly appreciated!
  • 3 Answers
I had the same problem with my Francis Francis X3 overheating. I'm certain the thermostatic controls are similar and I suspected that as the problem. I did not want to pay the roughly $180-$200 to send it in for repair so I opened the X3, located the thermostat and discovered that it was a Prodigy Italiana TR/86 30C-120C adjustable thermostat with the temperature control knob removed and the "P2" wire-lug removed. I could not find one online, but later discovered that Chris' Coffee Service sells it for the Zaffiro here: http://www.chriscoffee.com/products/home/isomacparts/zaffirothermostat.
You should probably open your X1 and confirm the thermostat(s) before ordering. Ironically, I ordered the thermostat, put my old thermostat and machine back together so I could try to use it for a few more days while I waited for the new thermostat to arrive, and all of the jostling apparently freed up the thermostat in my machine so that it started working properly again. The new thermostat arrived and it is an exact match, so I have set it aside for when the orginal one permanently fails, and I know it will. Good Luck!
Posted on May 02, 2008
SOURCE:
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Heats up ok but no steam when temperature reached
Water indicator light keeps flashing and bleeping even when iron is full ,this is a brand new iron.
Sep 26, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Phillips double-speed 2.5 bar reservoir heats but will not steam
Thermistor is probably damaged, and the machine does not identify that the steam is ready (max temperature was reached) and pressing the steam button wont do anything. Change the thermistor (should be carried out by professional technician).
Jan 04, 2013 | Philips Irons
STEAM FROM EXAUST
When you first start the car in cold weather it is normal for the exhaust to emit water vapour (steam) until the engine reaches normal running temperature.
Jun 12, 2012 | 1994 Jaguar XJ6
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Steam escapes while machine tries to heat up
That big nut is the pressure relief valve. It should normally be closed, unless the machine overheats, in which case it will vent the steam, thereby preventing an explosion.
The valve design means that it's somewhat normal for some steam to vent as the machine heats up, but once it gets close to working temperature, it should seal.
Pavoni does now have a replacement valve that avoids this problem. When your machine needs a major service, hopefully more than 5 years from now, you may decide to get the upgraded valve fitted.
Fergus.
Aug 22, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
The Enviro Steam cleaner isn't very hot..
Maybe the tank is over full. You need to leave room in the tank for the steam. Be sure you are waiting long enough for the tank to reach the correct temperature.
Jul 29, 2008 | Electrolux Envirosteamer 370A Canister...
Muffler
whenever air is compressed, as inside your cylinders, water is squeezed out of the air and does not have time to evaporate back into the air until either it gets past the exhaust completely (you see tailpipes steaming on cold mornings) or if the exhaust system has reached sufficient temperature and actually allows the water to "steam" out of the system at an earlier location in the system, then yopu don't see steam.. Many exhaust systems are ruined quickly when drivers take short trips only and not long enough to reach high exhaust temperature. You can always tell, by looking at tailpipes on cold mornings, which drivers have just started out and which have been traveling a long distance because of the steam issue.
Jun 12, 2008 | 1995 Pontiac Bonneville
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
2,122 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
andyandrews3
Level 1 Expert
ray gallant
ray gallant
Tom Chichester
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
