Question about Canon Rebel XT / EOS 350D Digital Camera
My cannon rebel xt says error cf how do i fix it. was taking pictures took mycf card out to veiw on computer when i put it back it says err cf. tried different cf cards and it says the same thing. help
  • 1 more comment
  • cjbj8890 Apr 29, 2010
    i tried that. i made sure all my pics were on my computer. i formated it now it says err 99. tried to take the battery out no change
  • cjbj8890 May 11, 2010
    thanks for your help this did not work we finialy took it to a repair shop and she had 2 prongs bent. so its in the shop being repaired. She looked but didnt see the bent prongs thanks again for your help
    we tryed 5 different cf cards. we took it to a camera shop she has 2 prongs bent so they are fixing it. thanks
    Problem Solver:
  • 6 Answers
Step 1 Try to use a different CF card
Step 2. Remove the card and visually check the Compact Flash compartment on the camera.Use a flashlight and check the inside contacts (2 rows of thin golden pins). All the pins should be aligned & straight, and the Compact Flash compartment should be clean with no dirt or foreign objects inside.If you nottice some junk (stuff) in there you can try to remove it ( pull out the battery first) blowing some air (not canned air, only manual blower !) or pickup all the junk from inside with a toothpick or plastic tweezers.If you are NOT comfortable doing this, or have no experience in dealing with the very sensitive electronic parts, DO NOT TOUCH anything, just visually chect the inside and DO NOT try to remove the dirt (junk, stuff) mechanically, use just air.Use common sense and do it on your own risk ! You can damage your camera very easy ! If the pins are bended/broken/missing you have to send the camera out for service.
Step 3.Reset the system removing BOTH batteries !.You have to remove the small 3 volt memory backup cell to. It is a small round button cell battery located inside the
battery compartment.Leave the camera for 20-30 minutes with no battery, you can press the shutter button for few seconds to be sure all the power was consumed from the capacitors.Put back the battery , restart and see if it works.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.Due the fact is a 5 years+ camera you have to put in balance if is a good deal to send it out for repairs or to replace it.Good Luck.Let me know if worked.
Posted on May 06, 2010
    Brigadier General:
  • 11,967 Answers
Sounds like you didn't use the "safely remove hardware" function when you removed the card. You need to download the pics off the card and then format it in the camera to get it to work properly.
Posted on Apr 28, 2010
  • Ty Price Apr 29, 2010
    Go into the camera menu and see if your camera has a "reset" function. If it does, reset your camera. If it doesn't, then remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. Let me know your progress.
ERR CF and ERR 99
there is cf unit faulty might pins are bent or damage and could be come out from board that why giving cf error and err99
Jul 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt eos shows ERR CF. What do I do now?I tried a new flash card but still got the same error message. When I try to preview pictures I have already taken the screen says ¨no image¨. My...
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
May 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Get Err CF in view finder and cannot take pictures
did you try removing the memory card and making sure its not locked?
Mar 18, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
Jun 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I took pictures without a card. How do I view them?
You can try connecting it to your computer via the usb cable...
Jun 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CF Card Err
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins?
You maybe able to fix it with pincers and a needle just align the pin or pins that are out of place, i did this and it worked for me and now my camera is working fine. and for free.
Good luck
Mattias
Oct 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I am getting a ERR CF with my Rebel XT
You've probably gotten bent pins in the camera. Has to go to the shop.
Oct 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon camera problem
Can you read the card in your camera?
If you cannot read the card in the camera...wow and ouch.
Try to get the card to a friend or someone who can read the CF.
Then see if they can read the card.
Hate to say it, but with an error like that, it may mean that the CF card is not working.
Are you trying to read the CF card on a reader on the computer?
Try your usb cable to the computer instead of the reader.
It is possible that the driver has become corrupted for the reader on the computer. Try the above, see what happens.
Jul 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
548 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
