Question about ViewSonic VX2235WM Monitor
Monitor display stays for a few seconds only but has power always
We have got Viewsonic Monitor, Model VX2235vm, It is always connected to CPU, but its display stays for little time (approx. 3sec.). But the power is there for the monitor with power indicator in blue color.
When we connected another monitor with the computer, it works properly, and display stays for hours.
Kindly advise us how to rectify the problem.
  • 3 Answers
I have the exact same issue with mine. Viewsonic VX2235WM turns on fine for about three seconds when asked to by my software attempts, but then shuts into sleep mode. I agree completely with BudMrtn. The issue is that your monitor has been through some stress and one if not multiple of the problems is due to part failure. In this case I would suggest a capacitor issue. First off make sure, for a fact, that you have the appropriate drivers. ( For Windows 7 I would suggest using the unsigned drivers from Viewsonic for this model. Now the reason that it is cutting off after a few seconds is because one of the capacitors is not sustaining a charge. It is showing as on for a sec because it is getting the appropriate power to operate but it is not receiving the appropriate level to maintain and is either shorting or free flowing the voltage inappropriately. Now the real question is... do you fix this issue. Well the monitor isn't the most expensive, but it is nice and would be worth the trouble. I would suggest you take a practice run on yours to learn a little something about repairing this level of issue. It is not a very hard fix but it is a very technical one. Understand that to you it is dead already, so what is the worst thing you can really do to it. Use absolute caution when handling these type of repairs. Make sure it is unplugged and use a muli-meter to find your short. I suggest you try and repair this because it is not as dangerous as a CRT. With a CRT you have to watch for residual charge... now you are looking for a busted capacitor which you must realize does retain a charge and electrocution can and more then likely will occur. Use a surge protector in case you screw up. Now if I am right the capacitor you are looking for is not holding a charge so residual charge is probably not going to be an issue... but you never know. Also always keep in mind that even though we have the exact same result, the issue may be varied to a degree of almost infinity. It smells like poo, it looks like poo, it even taste like poo, but it might be a ham sandwich, or a pigeon. My point to all of this is that you should not look at this as a downed monitor, instead you should view this as an opportunity to better get to know your electronics and how to repair them. Have fun and good luck.
Posted on May 27, 2010
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 28, 2010
Viewsonic vx2235vm does not turn on
This really sounds like you have a power supply board that is having problems with the filter capacitors which are causing it to not start up correctly. Here is a like to a repair guide including video instructions showing how to open and repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Part one of the video guide:
Feb 07, 2013 | ViewSonic VX2235wm LCD Monitor
Its not showing anything but it has power
please check whether the VGA cable is properly connected to your monitor and CPU and check. it should work. if not try with another cable.VGA cable and Pin will be blue in colour
Feb 13, 2011 | ViewSonic VA703B LCD Monitor
Monitor displays then shuts off
Have you verified the video card in the computer with a different monitor? Does the going to sleep message come up prior th the monitor going dark? The bulbs are ok since you do see a picture for a short time. The voltage swing you see on the power supply is too large. It should always be 12 v + or- 10%.
Mar 28, 2017 | ViewSonic VG900b 19" LCD Monitor
Monitor will not power on. All of the connections
yes all the connection are intact, in these cases have the cpu check the monitor is not the problem, the monitor is still displaying which means that it is good, have the cpu check or check how many vga adpater is present in the cpu, if you have a built in and a separate card and you plug the monitor to the built it will not work and you need to connect it on the separate expansion card that is install inside your cpu
michael
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Sep 10, 2009 | Computers & Internet
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Jul 28, 2008 | ViewSonic VA702b 17" LCD Monitor
Color Flashes
reset monitor to Default[see instruction manual]as I did with my Viesonic different model. if not a fix then check OS settings in Control Panel-Display setup. also, check you wiring and connections. finally, the video card itself may not be seated properly in CPU. generic answers since you did not furnish enough data.
Jun 21, 2008 | ViewSonic VX1935wm LCD Monitor
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VX2235WM Monitor Logo
973 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
