Question about VeriFone OMNI 3200 (P092-101-10) Printer
Englcdt.dat error message
Just purchased this unit at an auction. When I plugged it in, I got a vrr2 error message. Tried to reset by suggestions here but now I get a flashing "englcdt.dat" message.
  • Peppercandy Jul 08, 2008
    Got an Omni 3200 in ebay. When Pluged, it flashes Error / ERP1THIN.FRM
  • blueyedmdt Jul 24, 2008
    I am getting a vrr1.out message on mine after thunderstorm.
Got the same VRR.2 ERROR message, but when I reset (hold 6 and enter and the same time for a few seconds) it went back to the main screen. Hopefully I didn't clear any important information!
Posted on Jul 22, 2008
SOURCE:
I need to find a Digital Audio Tape (DAT) deck to play Maxell R-124DA and TDK DA-R180 tapes. DAT tape decks are no longer manufactured. The tapes contain voice and limited music and number between 100 and...
Dat equipment is readily available on Ebay and at sometimes unbelievable prices. Wouldn't you think manufacturers would stick to a format and stop inventing new ones just to sell more units and making perfectly good equipment useless. Pawn shops is a good place to find unused hifi gear also.
I just did a quickie search of The US Eby site and there are 1471 entries for DAT storage and player units. Some as low as $10 and dat tapes as low as a cent. Take a look, if Ebay scares you I can assure you there are more ripoffs happening in retail stores than on Ebay. I've been merrily saving a fortune on all types of equipment ever since it arrived in Australia. Buy the gear for next to nothing and do the work yourself, at least you'll know it's been done properly. There's even units which mount straight into your computer. DAT machine, editor and CD machine all in one. I might do like wise. I have a large collection of DAT tapes I picked up at an auction. HMMMMmmmmm.
Apr 23, 2010 | Audio Players & Recorders
Have a Karacher k-3.86 ELECTRIC pressure washer
Check the reset button on the GFCI plug to be sure it's in. Once you pull the trigger keep holding it for at least 10 seconds to let the water push the air out and then it should start running.
Apr 16, 2010 | Karcher K 2.25 R Electric Pressure Washer
Hi! I just plugged in the charger on a new
if you bought this new and your getting that error, i would take it back and get another one or have it sent back to magellan...
if your getting that error, your probably not able to access it via a usb cable to your computer and if the computer cant see it, you cant fix it.. actually, you can fix it, but its a royal pain and i wouldnt recommend telling you how if its under warranty.
bill
Sep 28, 2009 | Magellan Maestro 4040 GPS Receiver
PMSUER.DAT message on Printmaster Platinum 15
Have a look here.
http://support.encoreusa.com/kb.asp?id=144
Sep 12, 2009 | Broderbund PrintMaster Platinum 16
Dell tech in who-knows-where told me to reinstall operating sys, XP Home. About half way thru, error message, "Windows detected fatal error, shutting down." Tried 2 times more same message. Help! Dimension...
The fatel error is cause by memory/ and or CPU giveing out if the unit is under warrenty then I would suggest having them diagnose it , if its not then purchase some memory with the same spec's and try reloading again.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Dell Dimension B110 PC Desktop
Screen message: "Unable to print
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Feb 19, 2009 | Brother MFC-425CN Multi-Function Center...
Pioneer GPS - AVIC-S1
Main screen ---Settings ----Keep follow the 1st page, you will see the restored function as Restore Factory Settings.
Apr 13, 2008 | Pioneer AVIC-S1 GPS Receiver
Ricoh Aficio fax 5000L (error code & Factory Settings?)
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
Nov 27, 2007 | Ricoh FAX5000L Plain Paper Laser
SONY TSL-S9000L error message
Hi RIO,
I need a little more information to better assist you with your problem. What Operating System are you running and how old is this unit?
Is this the first time you are using this device?
Also look at the event viewer for info on the actual error, which could help to better explain what the problem might be.
--Roadhawk
Nov 24, 2007 | Sony TSL S9000L (TSL-S9000L) DAT Tape...
VeriFone OMNI 3200 (P092-101-10) Printer Logo
618 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
