Question about ASUS P4S533-VM (P4S533-VM/L) Motherboard
Computer noise I own a Sony desktop. The machine has been acting up for a while now. It would start up fine but sometimes while working it will start to make a noise sounds like a fan issue not quite sure but it would continue doing this then all of a sudden it will freeze up. Other times it will not even boot up. Any thoughts??? thanks
  • 99 Answers
Get a can of compressed air and clean out the fans, cpu fan, power supply fan. Could be from dust buildup.
Hope this helps!
Posted on Mar 24, 2008
SOURCE:
My Dell Studio XPS 7100 Desktop Computer has suddenly developed a whirring sound. What could cause this?
That is a fan causing the problem. First thing to do is open the side panel and clean out the dust, sometimes that helps. Next, with the side panel open, turn on the computer and look to see which fan is causing the noise, they are easy to replace. If it is the CPU fan it may be a more involved repair but its usually not too bad.
Dec 18, 2012 | Dell Studio Xps 7100 PC Desktop
Hi, I have 2 computers one laptop Sony Vaio and a
If the windows7 operating system is 32 bit on one computer and, 64 bit on the other the drivers will not work on both computers. check this and, if this is right; download the correct drivers for each machine and, install them.
May 09, 2010 | HP Scanjet G4010 Flatbed Scanner
No video on boot. After several boots all works
Hello my friend this is looks like your graphic card is dying or your power supply.You should change your graphic card but if you hear any noise let me know
Feb 06, 2010 | Sony VAIO PCV-RS510 PC Desktop
Computer resets for no reason and screen is getting lines in it. It is a Sony Vaio VGC-RB38G.
if its rebooting -then it could be an overheating problem- make sure the fans are working
Oct 13, 2009 | Sony VAIO VGC-RB38G PC Desktop
Sand
use a vacume to **** up most of the grit. DO NOT USE COMPRESED AIR. if the lens is making crunchy noises. basically all the internal gears are done. sony wont touch cams that have been droped in water or sand. try the vacume thouh it has worked before.
Jun 04, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
Just had ps3 hard drive fixed its now saying erorr 80010514
it is still the hard drive i had the same problem send it back again that is what i did and it worked after that
Apr 07, 2009 | Sony Playstation 3 (PS3) Console
My computer makes a loud noise in the fan
The drive door issue may indicate a virus infection. As to the fan, you would have it replaced. If not under warranty open the case and track which fan the noise is coming from
Mar 25, 2009 | E-Machines eMachines Desktop PC
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
HP desktop- is not starting up.
Let assume that the machine is fine. Is the display powered? Is the data cable from the display correctly connected.
The reason I am assuming your machine is fine is because it a name brand box. And when a video card fails on an HP you get a series of beeps from the computer. The same goes with the CPU and memory.
So if the machine is not beeping, it's generally one of two things. Connections or, sadly enough, a dead system board.
Hope this little bit of direction helps,
Paul
Aug 26, 2008 | HP Computers & Internet
ASUS P4S533-VM (P4S533-VM/L) Motherboard Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
