Question about Watches
Why do all watches stop shortly after i put them on?
  • 299 Answers
Tghere are really only two reasons a watch will stop unless they are damaged or wet inside. If it's a quartz watch the battery needs replacement. If it's a mechanical watch you have to wind it - even if it's a "self-winding" movement wind it to get it started. Turn the crown about 40 turns clockwise.
Posted on Apr 28, 2010
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
Watch stopped running - thought it was the battery. New battery did not start warch. I love the style of this watch and would like to repair but the repair cost would have been three times the cost of...
When a new battery is installed it is often required to short the case of the watch to the chassis of the watch (using tweezers). This resets the watch. Some watches have "AC" inscribed at the point where the shorting should be done.
May 05, 2011 | Watches
My watch stops 1-2 minutes after setting it. I pull out the knob and the second hand stops. I set the time and push the knob back in. The watch starts to tick as it is supposed to but it stops shortly...
mcdevito75 here, Sounds like your Rolex needs a reular serviceing, Check with the Repair Service Directory here at fixya, bottom of this page click on Reapir Service Directory, then watches, choose a repair service that specializes in Rolex watches.
Jul 10, 2010 | Chase 18.5mm-29.5mm PRECISION ROLEX OYSTER...
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Jul 01, 2010 | Rolex Day-Date President 118238 Wristwatch
Breitling Colt Kinetic Watch - not working
I read the instructions for a similar type of watch and while the battery will keep the watch "alive" for some months when not in use, eventually the battery dies.
Since it is a kinetic watch the instructions I read said that you should gently shake the watch about 500 times to recharge the battery!
If you give it a good shake and then wear it for a few days, it should recharge itself, although it may have forgotten the time and may need re-setting.
Mar 01, 2010 | Breitling Colt Oceane 504 Watch
How do I set the Pulsar Alarm-Chronograph N944-6A00
Short answer: You download the Operational Guide from Pulsar:
http://www.pulsarwatches.com/home2.asp#FAQ (look for N944 which is PGC series).
Longer answer: It is baffling to do this without the manual. You put the watch in -0- mode (crown fully in), pull the crown out to first stop, then us the A and B buttons to zero the 1/10th and second hands, then pull the crown out to second stop, then use the A and B buttons to zero the minute and hour hands. Then, you put the watch in "Time" mode (crown fully in), pull the crown out to the second position, and use the A and B buttons to set the time. You have no functioning second hand except for the stopwatch - in Time mode it acts as the calendar hand.
Dec 16, 2009 | Seiko Pulsar watch
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Jan 10, 2009 | Rado Diastar Anatom Jubile watch
Indiglo button kills watch function
I have the same problem with my watch. I replaced the ML-2016 battery myself. (which I found at Walmart) But when I press the iniglo button, it just stops the clock and I have to press the start/split button to get it to resume. No idea how to get the problem resolved
Aug 19, 2008 | Timex 5J261 Solar Powered Ironman...
Watch stops intermittently.
Make sure the dial that is used to set your watch is snug against the frame of the watch. Sometimes when people reset the time on their watches they don't push the dial all the way back in which will cause it to stop. If it is an intermitten problem it may be close but not all the way in. Some watches continue to run when they are being set; whereas, some stop when the dial is pulled to reset them.
Feb 02, 2007 | Tourneau Safari P6001/2-BLU
Watches Logo
124 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
