I have an Acer Aspire 5630-6288 Laptop.
Specs:
Intel Core 2 Duo T5500 (1.66 Ghz, 667 MHz, 2 MB L2 cache)
160 GB HDD
2GB DDR2
802.11a/b/g wireless LAN
Windows Vista Home Premium
My problem is that my laptop starts Windows normally and once it goes into the profile screen I have about 15 seconds to a minute before the laptop shuts off without warning, beeping or any written words. Never had a problem before this about two nights ago.
The system restore I've tried and it did not work, and whether plugged in or not did not matter either.
Had this laptop for about 2 1/2 years and any help would be appreciated before I do anything drastic.
Thanks, Ryan
Part Number:
Aspire5535 Aspire 5535
Feature
Description
Part Number
Varies by specifications
Processor / Speed
AMD
Turion™ X2 Ultra dual-core mobile technology
ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50
GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology,
or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1
MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD
HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor
QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W),
supporting AMD HyperTransport™ 3.0 technology.
Core Logic Chipset
AMD M780G Chipset.
System Bus Speed
667 MHz.
RAM / Max RAM
Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules.
Video Subsystem
ATI
Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of
dedicated system memory, up to 1792 MB of shared system memory),
supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR)
technology, Shader Model 4.0, Microsoft® DirectX® 10.0.
LCD Properties
Display 15.6"
HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer
CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via
Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time.
Hard Disk Drive
120/160/250/320 GB or larger hard disk drive.
Optical Drive
8X DVD-Super Multi double-layer.
Battery, Primary
48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use.
Sound Subsystem
Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone.
PCCard Support
1 ExpressCard™/54 slot.
Pointing Device
Touchpad
Peripheral Subsystem
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model)
Modem
56K ITU V.92 PPT approved, Wake-on-Ring ready
Ethernet
Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model)
Dimensions / Weight
15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack.
AC Power
100-240V AC AutoSensing Adapt
I've been asked that and it does this problem even after hours of being idle plus when I'm in safe mode (even for hours at a time) there is no shutdown problem
