Question about Kenmore 24032\24036 Top Load Washer
The eashing cicle stops before starting to drain
The washing cicle stops before starting to drain
  • Anonymous Mar 22, 2014
    the cicle start then after few second stop and ask again to select a program
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Apr 28, 2010
Maytag mah8700aww clothes wet after cicle
You might need to replace the drain pump. Make sure to listen if you hear the pump kicking in
Jul 25, 2012 | Maytag Washing Machines
Cda 497/1 not washing
see this possible causes: Water-heating cycle the cicles compren washing, and rinse, the machine stop, because the heating element, and thermostat can be defective test.see the diagram Timer test the timer see the diagram for defective, clean contact, with special spray, tigh the wires very well. 5_9_2012_10_57_35_am.gif5_9_2012_10_57_57_am.gif
May 08, 2012 | Dishwashers
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Won't drain or spin out
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Dec 12, 2008 | Danby DWM99W Top Load Washer
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
My dishwasher want run any cicles
check the out flow tube and see if its blocked..... if its not see if the food grinder in the bottom is blocked
May 28, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Flashing lights
You have a heat problem, using a test meter check the heater element, then check the thermostat if niether of these you have a PCB fault Regards Engineer
Mar 15, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Kenmore 24032\24036 Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
