Question about Dell Netbook
How can I copy and install a program file from my notebook to my netbook using a usb flash drive?
    Sergeant:
    Champion:
  • 305 Answers
Unless its on a disk you cant. however you may be able to download it and save to your flash drive.
hope this helps
Posted on Apr 28, 2010
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
Tip
How to hack Windows password on your netbook / laptop using a USB Flash drive
Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0.
Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0 to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen.
In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password.
After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password.
It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
on Jan 06, 2010 | Computers & Internet
Recovery acer5538
What is this
Do want recover your acer to factory defaults.?
or
use a usb memory card (usb drive)
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen.
The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options.
Choose "Factory Restore" to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
An example on how to safe documents , photos or data to a usb drive
Click start all programs accessories open windows explorer navigate to your photos
Right click on the documents , photos select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them
or if you are downloading data or programs from the internet
once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb device
May 16, 2013 | Acer Aspire One PC Notebook
I own microsoft office 2007 how can I download it onto my new hp mini110 which has no cd slot
"I have a netbook with no optical drive. How can I install Microsoft Office? A friend says I have to either buy Office as a download from Microsoft or get an illegal download - don't like either of those options. " Charles C from Iowa among many have asked this question.
There are several options for installing software onto a computer with no CD / DVD drive. We'll focus on Microsoft Office (as usual) but the same techniques can be used for almost any programs.
All these suggestion boil down to a simple truth - you can copy the contents of the Microsoft Office install disk to a folder which can be accessed from the netbook.
We have plenty of other netbooks on Office tips in our feature: Using Office on Netbook computers. Like this article, our feature was written on a netbook computer, so the advice is from hard personal experience.
Install disks are NOT that special There was a time when install disks were specially made so you could not copy them easily but those disks are rare these days. The installation files for Microsoft Office can be copied just like other files.
What really matters is the Product Key that's supplied with your purchase - it's that 25 character key which allows Microsoft Office to work normally. See What happens if your product key is stolen?
USB memory stick The easiest option is to copy the entire contents of the install CD to a USB memory stick or portable drive then plug that 'key' into the netbook.
Make a folder on the USB drive called, for example, Office 2007 Standard install.
Then copy the whole CD/DVD (sub-folders and all) with the root folder of the install disk copied to the new folder on the USB drive.
Office install disk copied to folder on removable drive
When you plug the USB drive into the netbook, navigate to the install folder (ie what was the root folder of the original CD/DVD).
Double-click the setup program or right-click autorun and choose Install. This will start the install process just as it would from the CD/DVD.
Share a CD/DVD drive On a Windows network, any drive can be shared and 'seen' across the network by other authorized computers.
Go to the desktop computer, right-click on the CD/DVD drive and select Sharing (the exact menu wording depends on your version of Windows) then share the drive with appropriate permissions.
On the netbook computer, go to the Network option on the Start menu. Navigate to the desktop computer then the shared CD/DVD drive. You can then see the contents of the install disk, click on setup or autorun (as above) and the installation will begin.
Apple promoted a 'special' remote CD feature when they released the Macbook Air. It was hailed in many quarters as a wonderful innovation, despite the fact that Windows users have been able to do the same thing for years.
Copy to netbook across the network If setting up the CD/DVD as a network share doesn't suit, you can simply copy the install disk contents to a new folder on a desktop hard drive which is shared and accessible from the netbook.
On a Vista desktop machine the easiest option is copying to one of the 'Public' folders then make sure those folders are shared with the local network. The netbook computer can 'see' that shared folder on the desktop machine and you can install from there.
Alternatively, copy from the desktop CD/DVD to the netbook computer. Make some folders on the netbook shared with write permissions then open Explorer on the desktop computer navigate to the shared folders on the netbook. Copy the contents of the install CD/DVD from the desktop computer to the shared folder on the netbook. Install from the netbook folder.
Plug in a CD/DVD drive There are plenty of cheap USB CD/DVD drives available which you can buy to plug into your netbook. However, as you can see, there is usually no need because you can access an optical drive from a desktop computer via the local network.
Repairing Office In the olden days (ie a decade ago) if Microsoft Office had problems you'd have to dig out the install CD and reinstall.
For the last few versions of Office (Office 2007 and Office 2003 at least) that's rarely necessary. When Office is installed a copy of the key installation files is put in a hidden folder - if (when) Microsoft Office has a little nervy an auto-repair system should start and restore files from the source. Re-using the install disk is less common these days.
Article posted: Wednesday, 27 May 2009
Jun 17, 2011 | HP Computers & Internet
Can i install windows 2007 on my hp notebook without the cd or dvd on it?
Use a computer with a CD drive and copy the installation CD files to an USB flash memory drive, then insert this USB flash drive into your HP notebook and install Windows using this USB flash drive.
Feb 15, 2011 | Computers & Internet
I have a mini notebook and would like to install office 2007. I cannot install using a cd rom since there isn't one. is there another way I can do this?
Install it from a hard drive... or.. set your pc on a network then share the cd room on the other pc ot he network... run and install the application...
Dec 30, 2010 | Microsoft Office Professional 2007 Full...
My inspiron 910 has SSD or software problem. I could not start my Windows XP. My questions are: 1.How i could get my Resore Window's files? I do not restore CD or any other CD with it; I have only...
1. To access boot options on this netbook press 0 on startup. This gives options to start from usb drive or external cd.
2. If you have an external cdrom, then use this with any xp home cd to attempt repair/ repair installation/ re-installation.
3. unetbootin allows you to create a bootable usb from a cd image (or you could use it to make yourself a linux netbook).
Aug 10, 2010 | Dell Inspiron mini 9 - Black , Intel® Atom...
How to load programs onto netbook
If you can't get an external drive, then download a (free) program such as Daemon Tools to your desktop machine and make an "image" file of your Office CD on your desktop, then copy the image file (typically in .iso file format) to a USB drive, then download Daemon Tools to your netbook, plug in the USB drive with the .iso image file on it to your netbook, then use Daemon Tools to "mount" the iso image as a "virtual CD" drive and install Office that way. Sounds complicated but it's really not -- Google "Daemon Tools" to check out that program --
Mar 27, 2009 | E-Machines emachines (emachinees) CD-ROM...
Dell Netbook Logo
Alun Cox
