Question about Texas Instruments TI-30 Xa Solar Calculator
Need to put in 50 tan 86 enter I have no enter button so what do I use?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Use the = key in the lower-right corner.
Posted on Apr 28, 2010
How do i change the setting to degree?
Press [2nd][MODE] to enter the default setup screen. On the third line Radian, Degree, highlight degree and press ENTER. From then on, angle values will be interpreted as degree values.
Feb 26, 2012 | Texas Instruments TI-86 Calculator
Cot(x) = -0.6
Let's start with a little background.
The cot(x) is also known as the cotangent(x) and it equals 1/tan(x) which equals cos(x)/sin(x). I'm showing these formulas because your calculator may not have a cot button but it will probably have buttons for tan, cos, and sin.
Your calculator may also have buttons for tan-1, cos-1 and sin-1. These are the inverse functions for tan, cos, and sin. If you enter a number and then push the tan-1 button, the result is the angle whose tangent is the entered number. For example, it you enter 1 and push the tan-1 button the answer will be 45 deg because tan (45 deg) = 1.
Now let's look at the problem, cot(x) = -0.6.
The first thing we need to know is do you want the answer in degrees or radians? Your calculator will have both modes. The default mode when you first turn it on is probably degrees. If this problem is in radians you will need to change the mode of your calculator over to radians before we start.
If cot(x) = -0.6, then tan(x) = 1/-0.6 from the formula I showed in the background section.
This means tan(x) = -1.6666666...
Now we just enter -1.66666667 and hit the tan-1 button to get the answer.
If we're operating in radians the answer is -1.0307 radians.
If we're operating in degrees the answer is -59.036 deg.
I hope this helps you out.
Dec 06, 2011 | SoftMath Algebrator - Algebra Homework...
How do i use tan on my calculator
Tangent is a trigonometry term. It is used to find the Opposite/Adjacent ratio when given an angle measure in a right triangle. The proper syntax is tan(angle measure).
Dec 17, 2009 | Computers & Internet
I need to know how to put in the info for tan^(-1)(whatever)=
Press SHIFT [ATAN] whatever ENTER
ATAN stands for arctangent (inverse tangent, tan^(-1)) and is the shifted function of the tangent key.
Aug 27, 2009 | HP 39g Calculator
Inverse Functions on Casio fx-270W PLUS don't seem to work
because cotangent, cosecant, and secant are all inverse trig functions, just type in 1 / |shift| trig function and the number if you are finding the angles. It might not be a dedicated button, but its an extra push, and it will give you the same result. *note that I put the shift press only because that is how you get the inverse tan to get an angle from a tan ratio.*
May 04, 2009 | Casio FX-270W Calculator
How to use the cot function
I don't have a Cot button but Cot x = 1/Tan x so enter
1/Tan 78 = 0.212556 etc if you have a fraction button you can write it that way too:
1 frac button Tan 78 = 0.212556 etc
Jun 16, 2008 | Sharp EL-531VB Calculator
Excel calculations
Just enter using this style
TIME IN TIME OUT HOURS 10:00 16:50 6:50 10:22 17:34 7:12 9:00 10:00 1:00
the formula in HOURS is Time Out - Time In
Mar 20, 2008 | Computers & Internet
Fractions
When performing the calculations, put the fractions in parentheses. Then once you get your answer, press 2nd and Math (above the times button). Then press F5, MORE, and F1. It will have Ans Frac>. Then hit Enter and it'll change it to a fraction.
Feb 03, 2008 | Texas Instruments TI-86 Calculator
Sin cos tan
37 is in degrees. so if your dealing with degrees you need to go to and change the mode. hit the mode button next to the 2nd button and go down to and change it from degree from radian by going to degree and hitting enter
Dec 05, 2007 | Texas Instruments TI-83 Plus Calculator
Need help withe the sin, cos, tan problem with ti - 83 plus
here are the steps in changing it from radian to degrees
1. turn on your TI-83 plus
2. press the MODE button near the top of your calculator
3.go down to options and move the highlight from radian to degree, press enter and clear
you're good to go
Feb 17, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-30 Xa Solar Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
