Question about Frigidaire PLHS67EGSB Stainless Steel Side by Side Refrigerator
Frigidaire Refrigerator - GSI-26 Ice Maker won't shut off
Model: PLHS67EESB3
Serial: LA52617904 Ice Maker Model:
Question: My GSI-26 Ice Maker makes Ice, but it does not shut off when the ice tray is full. As a result all the ice overflows into the freezer compartment unless I flip the on/off switch. Obviously the whole unit is not bad because it is making ice. So, what is the name of the defective part that I need to order to fix this problem?
  • hjathi Apr 28, 2010
    my ufs 3 box is auth error plis help me.
4 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: FRIGIDAIRE M.N. FRS26R4CWR AND S.N. LA52921475 ICE MAKER GSI-26
Is this the original ice maker? If it is you should be able to pull off front cap on icemaker head and see a adjustment screw with a - and + signs adjust towards - tell required level is reached.. most new model icemaker have NO adjustments.. has a circuit board for a brain..lol and takes care of the adjustments
Posted on Aug 21, 2007
woodchuck789
  • 4059 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
  • 130 Answers
SOURCE: my ice maker stopped making ice
The simple and most expensive solution is to replace the ice maker assembly. They sell for between 50 bux on e-bay to 150 bucks at Sears. From what I have seen most ice makers fit the same category and they look like they are all designed and built by the same company!!
The main problem is the gear on the backside of the unit snaps off for various reasons like ice cubes getting stuck and causing the ejector rake to jam, thus overloading the flimsy gear and snapping it off. You can not purchase the gear however you can choose to buy a gear-head assembly for 80 or so bux.
http://www.appliancepartspros.com/part_details.aspx?part_id=3177342&pn_=8201515
shows a typical repair kit. Just enter your model number on their website to find the exact match for your ice maker.
I repaired the broken gear on mine using some structural epoxy. Here is a pic of the repair in progress, The green stuff in the center of the gear is the epoxy I used. Good Luck!!
Posted on Jan 31, 2011
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a Frigidaire Model# FRS26H5ASB9. The ice maker is a GSI-26. The ice maker water line freezes up and then the ice maker does not work. It goes thru the cycle and it sounds like it is filling but no...
The most likely reason for this happening is a defective Click Here=> 241734301 Triple Water Control Valve These valves are located on rear of refrigerator and near floor where the water supply enters your Refrigerator. CLICK HERE=> FRS26H5ASB9 USE AND CARE GUIDE
The valve location is listed on page 5 of the Use and Care Guide, If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) This problem is typical as a leaky faucet that drips even when the water valve is turned off. I will be here to answer any questions you may have, Thanks Sea Breeze
If helpful please rate this solution, Thank You
Jul 16, 2011 | Frigidaire FRS26H5AS Side by Side...
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
My ice maker stopped making ice frigidaire model plhs269zdb1 ice maker model number is GSI-26
Dec 29, 2009 | Frigidaire PLHS269ZD Stainless Steel Side...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Aug 17, 2009 | Refrigerators
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side model:FRS26HF6BW2
Check the trap door where the ice drops through, it might be stuck in the open position, solenoid that operates the door may be bad.
Jan 27, 2009 | Frigidaire FRS26R4A Side by Side...
Aug 20, 2007 | Frigidaire FRS23H7CS Side by Side...
Open Questions:
See all Frigidaire PLHS67EGSB Stainless Steel Side by Side Questions
Frigidaire PLHS67EGSB Stainless Steel Side by Side Refrigerator Logo
453 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
