Question about Sport & Outdoor - Others
I have a Suzuki DT 16 outboard motor on a boat the motor is running great however there is water and oil mixed and dripping out of a part below gear selector on the shaft leading down to the prop there is a rod which moves as you select gears that is threaded and has springs on it the oil and water mixture is leaking out above this
  • andkye Apr 28, 2010
    Cool thanks
    President:
  • 1,857 Answers
Providing the housing did not crack which is faily common you going to have to disassmble and inspect. Hopefully the seal is just in need of replacement.
Posted on Apr 28, 2010
Suzuki turns over wont start 115 dt out board2 stroke
When did it last start and run well? Check for fouled spark plug. Ensure that ALL electrical contacts are CLEAN and TIGHT. Check fuel/oil mix for proper proportion and freshness.
Aug 28, 2017 | Clymer Suzuki 2-225 HP Outboards Includes...
I have a 2003 yamaha 40 hp four stroke outboard, this year started up seemed to run great after about 25 minutes i shut it down an hour later checked oil crankcase full of water
water in the engine crank case oil --major seal or corrosion problem in the motor
water in the leg gear box --
pump seal on the drive shaft
Jun 01, 2017 | Yamaha Boating
Water in the oil of my 4 cycle Suzuki boat motor, what could that be
without a model number its impossible to tell weather you have a oil/sealed water/water heat exchanger or water is directly circ thru block , if its the latter 4 sure you have a bad head gasket ( Happens on aluminum block) if its the first one id 1st ck the heat exchanger O ring seals
Nov 13, 2015 | Light Outboard Motor Boat Bass Fishing...
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
Suzuki outboard motor
Unfortunately for you, the motor is out of warranty and lower units are not supposed to be cracked under any circumstances other than striking very hard some underwater obstruction. IF water was present when the motor was put away last winter, it would have frozen, expanding in the confinement of the gear housing and causing the metal casing to CRACK. Water WILL then be able to intrude the gear casing and mix with the lube oil in the lower unit leading to a breakdown if you run it without having it replaced. Get it serviced as soon as possible or, at least, get a service estimate without using it further or you'll experience a catastrophic gear failure in the lower unit and find yourself defintely looking for a new motor.
Jun 01, 2013 | Boating
What type of oil for a 90 horsepower 1998 engine for a boat?
The outboard leg/transom leg oil is most important, where the gears drive the propeller it will need a heavy oil like hypoid gear oil No. 90. If it is a four cycle motor which doesn't need to have oil mixed with the gas, the base of the motor will have an oil plug and dipstick, and most likely take a high performance oil which acts as a coolant as well as a lube oil, so keep it right on but not over the full mark to avoid deadly engine heat.
If it is a Two-cycle motor you will need a 2cycle oil to mix with the gas according to that engine's particular mix strength on the instructions. Some are automatic oilers - 2cycle injection so you just keep the 2cycle oil tank full. You need to find a sticker on the motor or brochure to get the right oil weight and weather it can take the new multi-weight synthetic oils or not. Also oil the cables and steering pivots and all joints after you take it out of salt water and do your routine flush-out for the leg coolant water system with a hose - the coolant pump in the leg is not rust proof at all, even for fresh water boating.
Jun 21, 2011 | Garden
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 | Boating
Motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
Feb 25, 2009 | Light Outboard Motor Boat Bass Fishing...
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Sport & Outdoor - Others Logo
60 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
