Question about Kenmore 24 in. 17002 Built-in Dishwasher
Kenmore Quietguard 2 dishwasher not filling.
Kenmore Quietguard 2 dishwasher draining as fast as it fills. ?water level not getting high enough to raise float. I think the drain is not closing properly, could it be stuck?
    Problem Solver:
  • 11 Answers
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Posted on Apr 28, 2010
What can be wrong with my kenmore quietguard dishwasher if it does not fill with water
Most likely is is a stuck float or float switch. Next most likely possibility is a loose or broken wire going to the water fill valve. For some reason, mice seem to be attracted to this wire (usually 2 thin brown wires) - check for mouse droppings and look for chewed-through wires. Finally, if everything else seems okay, it is probably a bad water fill valve.
Sep 07, 2014 | Kenmore Dishwashers
E3 water drainng error
Some drain problems come from the washer drain hose not being high enough to allow for the water to fill in the dishwasher. Make sure the hose is held as high as the washer top as possible before it drains into the sink drain pipe. A good example is your cloths wash machine the drain hose comes from the bottom of the machine then it goes up to the drain that is higher than the basket. This keeps the water level high enough to wash clothes. The dishwasher works the same way. The drain hose must be slightly higher or as high as the needed level in the machine to work. In most cases as high as the dishwasher top or close to it. Simple raise the drain hose.
Jan 20, 2014 | Samsung DMB28AFS Dishwasher
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
check the water inlet valve first
May 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher
fatubu, are you sure you have the correct model number, Im not finding anything on the posted model. They had an issue on models close to this that had an issue with a twisted or missing seal in the pump assy. causing water to fill the pressure switch hose. The dishwasher would drain water after the fill. The fix was to replace the pump and motor assy. Catriver..post back.
Feb 18, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 17002 Built-in Dishwasher Logo
293 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
