Question about Sony Playstation 3 (PS3) Console
Ps3 error code 80010514
    Scholar:
  • 85 Answers
This is alot of info but you wanted to know. :P hope it helps
Gamerevolver.com recently had an interesting article regarding the dreaded 80010514 error. I hope many of my loyal visitors never have to encounter it. Their is a known issue with the PS3, simply known as error 800010514 which doesn’t happen often but when it does, it’s darn right nasty.
The error in question is mainly seen within the first month of use, or to put it bluntly, it has the error right out of the box, however, we have seen this occur at almost a year into service as well.
“An error occurred during the start operation. 80010514′
Gamerevolver.com recently ran into the the dreaded 80010514 error shortly after installing a new game they had purchased off the PlayStation Store and decided to document it. Here is what the have to say…
Since this error occurred, we obviously contacted Sony Support. We were informed that the code is not common, and a simple reset of the system, and restoral of factory settings should do the trick. Unfortunately, after the restoral, the error still occurred.
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
Basically, what is occuring is the corruption of game disc recognition and execution. If you will notice, in 90% of all cases, the drive will still play DVD and even Blu Ray movies with no problems. When trying to start a game however, the title, sooner or later, will receive the error.
1) Ensure that your internet connection is stable. If you are using a wireless connection, make sure your signal is at least a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner will tell you that the Playstation 3 is a dust magnet. Just run a dry cloth over it every couple days, and you should be fine. This will help prevent heat issues and shorts that may occur.
3) When installing firmware and/or software, make sure you follow the instructions. Even if you have installed 6 versions prior, each one is different, and may require additional steps. Save yourself the headache and just follow them, it only takes a minute or so longer to do it right.
Lets sum it all up, the error is not hardware related and is caused due to corruption of firmware. Restoring you PS3 will not roll back the firmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit. Again I hope none of my readers have to see the dreaded 80010514 error and by following Gamerevolver.com’s simple steps your bound to prolongue the life of your PS3 indefinitely.
(Update) Eurogamer.net contacted a SCE UK spokesperson which told them “”I’ve spoken to our Customer Services department and they aren’t aware of this issue with the PS3.” So take that as you will? Is the dreaded 80010514 just a myth? or an error that Sony is not aware of?
(Update 2) Try this before replacing Blu Ray drive (Last Resort)
Undertakerza updated a game, Warhawk and his system froze, got it rebooted it could no longer access any discs (cd, dvd, blu ray, games) he was ejecting and re inserting disks when I realized that the drive wasn’t making any noise and also … not spinning disks anymore they come out the exact same way he put them in.
Here is how he did it:
Ok so I’ve fixed my issue. I will run through what you will need to do to fix yours if you are having issues with the blu-ray drive and general PS3 system operations like the XMediaBar this is totally worth a shot … I doubt this will fix any other issue. If not then your blu-ray drive/ PS3 is probably dead and needs replacement via the method listed above or by sony.
If you can, I suggest you back up your PS3 first. The menu that you will access to can fully erase your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive.
However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem
UPDATE: With the new firmware 3.10 you may be able to report the error code directly to Sony via your PS3 console. Have a look here, please note that this has not been tested for this error code yet.
Posted on Apr 28, 2010
CLEONTI
  • 33 Answers
SOURCE: 80010514
Unfortunately this is typically due to a fault in the PS3 - most likely a problem with the Blu-Ray drive. Sony should send you a box to mail it to them and then it can be repaired if you are still under warranty.
SCEA Consumer Services
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00AM- 6:30 PM PST
If you appreciate the time I took to help with this, please take the time to rate my response.
Hope this helps,
Chris
Posted on Mar 24, 2009
Trippynet
  • 47 Answers
SOURCE: error code
Return under warranty, ps3 uses a high powered blu ray laser that can melt the lens after extensive use, sony is working on a fix and will repair this for you for free unless you have opened the case.
Posted on Feb 18, 2008
  • 149 Answers
SOURCE: ps3 error code 80010514
its not the blu ray its accually some form of file corruption that can be cause by many things
updating a game and the file was corrupted and is put into an inaccessable place on the file system or a firmware update that was slightly corrupted but should be an easy fix using the recovery consol.
to get to the recovery consol:
when the ps3 is in standby mode(red light)
press and hold the power button till you hear a double beep some times the systems will do a single beep then another single beep then turn back into standby mode, if it does this just let go of the power button and press and hold again real fast this time you should hear single beep then a double beep beep, then release the power button and plug a controller in usb.
choose rebuild file system
after it rebuilds do all the steps again to get to the recovery console again and this time choose rebuild database.
after its done you should be good, if not then you will have to re-download the latest firmware on a pc and do install firmware option from the recovery consol using a usb drive of some kind or a sd card if your ps3 and pc have those slots.
Posted on Sep 22, 2009
  • 393 Answers
SOURCE: Error messages 8001050F and 80010514 disc will not play
=-=- Here’s what’s going on right now: something with the PS3’s internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3’s clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
Does this affect me?
-If you have a Slim PS3, you’re good to go. Continue playing it as normal.
-If you have a “fat” PS3, you may be affected. Some fat PS3s have worked ok, but it seems a good majority have been bugged.
What does this bug mean?
-If affected, your date and time has been set to a random past date. This prevents you from signing into PSN, playing any PSN games, or using any DLC. Your trophies will also not display correctly or be able to sync.
How do I fix it?
-You can’t. Even if you don’t sign into PSN, it won’t help. This is a hardware issue.
So, what do I do?
-Wait 24 hours. Other products that have had similar bugs have corrected themselves after the “bugged” day. On Monday around 6pm central time, all PS3s will automatically correct themselves…maybe.
-If that doesn’t work, we’ll need a firmware update from Sony, which should be a pretty important priority for them right now.
Did I lose my data/themes/etc?
Your save data/games/dlc/themes are fine. They’ll be fixed when the PS3 is fixed. Trophies are uncertain right now, but they’ll be fine if you’ve synced them before the PS3 was bugged. Unsynced trophies are an unknown right now.
If I have a bugged PS3, can I still use it?
It’s probably not a good idea, as I have no idea what will happen to the trophies you earn during the bugged time. Movies/media will work fine.
Posted on Mar 01, 2010
kapishtech
  • 2272 Answers
SOURCE: PS3 error code 8001050f-80010514 and
This all error codes can be reset by the procedure.But if the lens is removed and there is a freezing problem then its a problem of lens alignment or the lens spinning motor is got loose or weak check it. click this link for the reset procedure:--For this errors. http://www.youtube.com/watch?v=1CJ9Q8bG-0s&feature=player_embedded -------- But if there is lens alignment or lens motor problem then it needs to be checked and repaired to resolved the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 29, 2010
Go to this link as it has nice info on how to repair the problem. Its too much to list here. :)
http://www.ps3errorcodesfix.com/ps3-error-code-80010514
Sep 15, 2012 | Sony Playstation 3 (PS3) Console
Error cod 80010514 ps3
the PS3 error code 80010514 is related to an error with the Blu-Ray disk drive inside your PS3 console
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
FIFA 11 game wont start (PS3) gives me error code 80010514. All other games work fine. Game works fine in brothers PS3. Never had this problem before. PS3 support says they have had a lot of calls with...
It's eiyther one of two problems:
The first is that FIFA 11 is screwed up due to an EA Sports programming glitch within the game - (see http://www.community.eu.playstation.com/t5/Technical-Help/FIFA-11-Error-80010514/m-p/11614173))
OR
The second is that your PS3 is dying and the laser won't read discs. Which gets progressively worse, or so i've read. - (see http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/)
I'm getting the same error but my PS3 isn't yet 12 months old, so is going back to the store.
P*ssed that I can't play the new FIFA though!!!!
Oct 02, 2010 | Video Game Consoles & Games
Error code 80010514 displays when i try to load ps3 games or they just dont load at all , ps2 games are fine
Hello Sir
80010514 - An error occured during the start operation; Ps1 game swapped using
the eject function and then play pressed quickly - ps1 game inserted
again
Oct 13, 2009 | Sony Playstation 3 (PS3) Console
Error code 80010514
Unfortunately, from what I have read, it looks like you should call Sony. This is a hardware failure code and has nothing to do with firmware. Hopefully the system is still under warranty.
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
My ps3 always write code error 80010514 and it freezes after 5min
you not really explaining why?
what are you doing that you are getting theerror code?
are you downloading somthing?
is it when you are playinga game?
when you turn it on dose it appear?
you need to explain....im waiting for a comment than i will help
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
Error code 80010514
Hello Sir , I'm Glad To Help You
80010514 - Disc error detected. Retrying operation
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
the problem should not happen again. but with all equipment with a disc drive, it is possible that the disc drive will fail and need to be replaced.the ps3 is just another computer and there are no garuntees
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
877 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
