Question about Sport & Outdoor - Others
Below the gear selector is a threaded spring loaded rod which moves when selecting gears there is oil mixed with water dripping from the top of this rod what would the problem be ?
  • andkye Apr 28, 2010
    This item is a suzuki DT16 outboard motor for a boat 16 horse power
    President:
  • 1,619 Answers
It would help to know what we are talking about. What equipment do you mean?
Posted on Apr 28, 2010
Testimonial: "I did not supply enough info but resubmitted another question with more detail"
  • Jason Johnson Apr 29, 2010
    Thank you, that will help us provide better assistance and good luck.
50 horse 4 stwont go into reverse gear due to shaft problems
the drive shaft just drives a pinion gear in the prop box that drives to gears that spin in opposite directions all the time
by selecting forward with the selector rod , a dog gear is moved forward to mesh with one gear that is turning or moves the other way to engage the other gear that is turning
that is the forward or reverse action for the prop
if you have forward but no reverse the it is not a drive shaft problem but a selector rod adjustment that is not moving the dog far enough to engage the running gear
Jul 08, 2017 | Cars & Trucks
1983 Johnson outboard . Model J25TECTE. Runs Forward/Reverse. Shift rod connection OK. Shift in neutral it runs in reverse. Do I need to change something in the gear case section?
you have removed the leg to replace the water pump impeller
the leg has the selector rod for the forward and reverse action
as the direction selection is a simple dog that moves forward or back to connect the spur gears and it was working before you pulled the leg off , then I am thinking that when the leg was reassembled that the selector was in a wrong position and now you are only moving it in one direction neutral or reverse instead of the 3 positions forward neutral reverse
nothing else can change except where the rod connects in the leg
Jul 07, 2016 | Boating
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/r1-wont-shift-past-2nd-gear.169723
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
Extended cab. How do I uncross gears?
if you are stuck in gear it is not a basic rebuild but a bad rebuild
because of the design of the gear selection process , it is impossible to have 2 gears selected together as one selector shaft will not move unless another selector shaft is in the correct position ( neutral ) to allow the detente balls to move out of the way so the next selector shaft can move
it is possible that the gear stick is not in the correct position when it was installed back onto the top of the box and one gear was selected and the end of the lever came out of the selector slot or all the selectors were not in the neutral position and so the end of the lever went behind a selector rail
pull the gear lever turret of the top of the box, move the selector rails until they all line up as a slot across all of them , then put the gear lever end back in that neutral slot
Dec 27, 2015 | 1992 Ford Ranger
Shifter loose like a spring is gone have to hold to left to work it properly 2007 suzuki forenza
get to the top of the gear box and you will find 4 bolts that hold the turret to the top of the box take it off and the gear lever comes with it . In the gear box there will be a slot across all the selector rails that is neutral for the gear lever. At one end of the slot you will see a plunger that is spring loaded This prevents inadvertent selection of reverse and it pushes the gear lever to the central position. check that spring operation
Aug 20, 2014 | 2007 Suzuki Forenza Sedan
Reverse stop plate problem?
IN the selector rails in the top section of the box there is a spring loaded de-dent ball that come into play when the lever is placed or pushed towards reverse. To select reverse you have to overcome this spring so that the selector rail can be moved. IF you can get a look at the top section of the box you may see a plug that is screwed in and facing the gear selector lever min the reverse position. If you can unscrew this plug there should be a spring and then a plunger of ball. I suspect that the spring may be broken or the plunger is stuck. If you can get to the gear lever pivot and remove it you will see the plunger that I am talking about . It should be in the removable top section
Nov 27, 2013 | 2006 Hyundai Tucson
Gear selection difficult nissan primastar
It's a bit of an common problem with this gear box the forward backwards selector arm ( the T shaped one on the left when viewed from the top) has an oil seal that is prone to failure allowing water to penetrate in to the gearbox. If left unchecked the selector bearing will eventually collapse making it impossible to get any gear. A further problem that can happen is that the main bearing in the box will also suffer from the presence of the water. Best way to check is to drain the oil from the box thru the plug on the bottom if the diff if it come out even slightly milky then the selector oil seal has failed only solution is to drop the box out and have the selector turret beaeing changed buy a recon specialist and have them check the main bearings for water damage too
Jan 05, 2013 | Cars & Trucks
Transmission problem.
sounds like syncro gear is out of it.
Apr 25, 2010 | 1996 Toyota Tacoma
Auto box oil change Renault Scenic, gearbox stuck in park
Did you replace transmission filter? It may be blocked with dirt and is causing gears to slip...
Jan 26, 2010 | 2003 Renault 181
Sport & Outdoor - Others Logo
61 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
