Question about Sony VAIO VGN-FS810/W Notebook
My vgn-fs810/w laptop is not powering up. Battery,
My Sony (vgn-fs810/w) laptop is not powering up. Battery, ac adapter, power port and Power button are all ok. What is wrong this picture?
Remove the battery from the laptop, and leave it connected only to the wall outlet. Then press the power button. The laptop should now power up. It worked for me.
Posted on Jun 08, 2010
  • Sony Master
  • 2,404 Answers
Motherboard is faulty. You can try removing the hard drive and dvd drive to make sure those aren't shorting out the motherboard. You can also try each memory stick to make sure neither one is shorting out the motherboard.
Posted on Apr 28, 2010
Vgn-tz3 F10
You can look for it on eBay.com. Usually there is a seller who sell one key for low price.
Jan 28, 2014 | iTEKIRO Replacement Laptop AC Power...
My vgn-fs742/w laptop is not powering up
Can you charge it ?
If Yes, you might have run out your battery, please charge it for at least 5 minutes, then try again to powering up.
If not, have you try to pull out your laptop battery and then plug the charger to your laptop then hit the power button ? is that laptop can boot up ?
if Yes, you might need to replace your battery
If Not, you can bring that laptop to service center :D
In some case, if after pull out baterry and laptop can boot up using power adapter direclty, you can put it back the battery to the laptop and the laptop will turn on normaly
Nov 15, 2012 | Sony VAIO VGN-FS810/W Notebook
There is a light on the power but if you press it on.... no lights at all
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 30, 2011 | Sony VAIO VGN-CR220E/P Notebook
I have sony vaio vgn-cr 353 model suffering for abnormal shut down problem. what are the posible cause? pls help me.
Jul 22, 2011 | Computers & Internet
I have sony vgh-cr590 laptop. For some reason there is no power. The AC adapter has the green light but I am not sure there is power to the computer. The battery will alos not work. I am computer savy...
sounds like a issue with your new ac adapter, or you can be dealing with a broken power pin, This is very common in Laptops, The Power Pin is a connection between your Ac adapter and the motherboard, often this pin is accidently broken causing no contact between the power port and the mother board causing your power issue. If it is the power pin, it will more than likely need professorial work, because the pin needs to be re-soldered back onto the mother board. Total cost for the power pin averages about 40 bucks and most techs will charge around 200 for the labor.
Hope this helps, take care and have a great week.
May 26, 2011 | Sony Vaio VGN CR590 Laptop Universal AC...
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
Feb 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Wont power up, today.
try doing this
  1. disconnect the ac adapter and the battery
  2. reseat the RAM or memory if you can. if not, its ok
  3. press and hold down the power button for 7-10secs even without the ac adapter and the battery to release static electricity
  4. reconnect ac and battery
  5. try turning it on
Jan 26, 2010 | Sony VAIO VGN-N110G/W Notebook
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Sony vaio vgn series doesn't turn on no power
You should try another ac adapter.If that does'nt work the power jack where it plugs in may be bad or the power board under the power button is bad.You should try another ac adapter first though.
Aug 04, 2009 | Computers & Internet
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Sony VAIO VGN-FS810/W Notebook Logo
223 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
