Transcend T-Sonic 840 MP3 Player Logo
Posted on Apr 28, 2010
How can I delete files?
How can I delete music files and folders?
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Apr 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
5577
Points
13
Here is the user Manual. It tells you how to delete files
How do I delete music off my Eclipse 180G2 mp3 player
Delete file- Allows you to delete a file. . Use [PREV] and [NEXT] to select a file and press [MENU] to begin delete that file. If the music is in a folder, you will see "/" at the top of the screen, select this and press [MENU] to leave the current folder and go up one folder level.
Dont know how to add files
When you connect the MP3 player to your computer with the supplied USB cable then computer detects the player as an external storage device or a Removable disk, you can then view the folder on your MP3 player. Open the music folder and create a new folder on the player exactly the same way you create a folder on your computer's hard drive. To organise your music, make a folder name with the name of the music album and place the album's MP3 files in this folder, then copy the mp3 files from the computer into this folder.
You will then be able to select the music you want to play by the music album folder. To delete a file from your MP3 player, connect the supplied USB cable to your player and then plug it into the USB port of your computer.
The computer will detect your player then click on this device to view the files, you can then click on the music file to highlight the file and then press the Del key to delete the file off your MP3 player.
How to delete songs
When you connect the MP3 player to yourcomputer with the supplied USB cable then computer detects the player as anexternal storage device or a Removable disk, you can then view the folder onyour MP3 player. Open the music folder and create a new folder on the playerexactly the same way you create a folder on your computer's hard drive. Toorganise your music, make a folder name with the name of the music album andplace the album's MP3 files in this folder, then copy the mp3 files from thecomputer into this folder.
You will then be able to select the music you want to play by the music albumfolder.To delete a filefrom your MP3 player, connect the supplied USB cable to your player and thenplug it into the USB port of your computer.
The computer will detect your player then click on this device to view thefiles, you can then click on the music file to highlight the file and thenpress the Del key to delete the file off your MP3 player.
How to delete songs from my Sansa m250?
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
1helpful
Itunes file twice the size as library
when you add music to your itunes library, it copies them to the itunes music folder for itunes to manage it or itunes has every song twice in its library, to check whether itunes has not copied your music twice, view your music in LIST VIEW in itunes and if you see some songs has been copied twice delete on of them.
You can also delete the songs on your music folder to save disk space or you can leave them if you use another music player other than itunes.
But I think you should delete the files in your music folder.
4helpful
2answers
Can you only delete files on the Archos 3 via a
Ok. With the Archos 3 Vision, in any mode (ie file viewer or one of the libraries) if you touch a file name and hold down on it, you will be given a prompt to either "Delete" or "Exit". I hope this answers your question. It took me a while to figure this out since the documentation that came with the product was absolutely horrible.
File deletion problem from Garmin c550
If your undelete program lets you undelete the _P3 folder, do it. Then try renaming it to MP3. See if this helps. This is the folder in which all of your music is stored. If it allows you to change the folder name, you should now see (and be able to delete) all of your music files stored on the GPS.
1helpful
2answers
How do I delete files?
The files on your music menu are connected to the folders on your computer. You can't delete the files from your music menu. You have to delete them (or move them) from the folder you took them from.
I suggest that you create a special folder on your computer for only the files you wish to put in coby media manager so that when you get a message like you mentioned you can get the files off your list by moving them back to your normal music folder.
I hope this helps!
_______________________
(^_^)*
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Top Transcend Audio Players & Recorders Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
