Question about Linksys Wireless-G WRT54G Router
Linksys Broadband Router Model WRT4G manual
I recently converted from using a cable internet connection (Comcast.net) to a DSL connection (ATT Yahoo High Speed Internet Express). How do I use my rounter so I can be wireless?
    Genius:
  • 3,422 Answers
You can download the manual from HERE.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 24, 2008
  • 871 Answers
About your question. in order to have a wireless connection., your router is required to have antennas. just like the picture here. they are called wireless broadband routers. they are not totally wireless since they still have to be connected to the phone line.
the idea of wireless is the connection from the laptop or desktop going to the router as no rj45 cable is needed.
since your recent ISP was cable, you had some converters right? i am not really familiar with converters of cable internet connection since we dont have that here in the phil. (in my area).
but what im telling you is that related to your question, you will need a wireless router to give signal...and a desktop or laptop that are able to receive signal from the router via wifi card, wifi usb...etc.
hope you got that.
thanks
  • earl norman llanera
    earl norman llanera Mar 24, 2008
    if youve got questions regarding your issue, im free to help.
    i have just visited your new ISPs webpage and they do offer free service to new clients like you. so if anything is not clear here, you can always ask your new ISP. thanks again.
  • 4,889 Answers
This link has all the info you will ever need to know about a wireless connection
  • eagle338
    eagle338 Mar 25, 2008
    Did you set it up?
    Genius:
  • 1,913 Answers
Install one wire less lan like airplus d-link lan card in pci
then
set your ip address to specific ip address like 192.168.1.2
also sub mask to 255.255.255.0
and gatway to your ip like 192.168.1.3
also set your dnd as your internet provider .\
    Genius:
  • 1,665 Answers
You must insert the code you have provided.
    Sergeant:
  • 406 Answers
Its wireless router.
When you have any wireless device like a laptop. you may connect wireless router and surf the net or mobile etc
  • Rafique Mannasaheb Mar 24, 2008
    here i am online and i am available for your feedback.
SOURCE:
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
Not able to connect with internet using my router
Had this work before?
If yes, and you're using Cable modem then just Power cycle the Linksys router by unplugging / plugging the power cord.
If not, then you have to configure it with the correct settings for Cable and DSL ISP connection.
Check you physical connections; Modem (cable or dsl) - to Linksys (WAN or Internet port) - then plug (wired) your PC to check internet connection.
Good Luck!
Angel
Jul 09, 2010 | Linksys Wireless-G Broadband Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Have changed to att may I use linksys modem
Yes, you can still use the Linksys router with your ATT dsl modem. Could you provide me with the model or brand of your ATT dsl modem so I could provide you with the steps on how to setup your router?
Feb 27, 2009 | Linksys EtherFast Cable Modem with USB and...
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Linksys router not performing
has it worked before? if yes, try to power cycle everything. turn off everyhting then turn on the modem first, then the router, then the computer/s.
if you have power cycled everything already and you still can't access the internet using the router,
- access the router's setup page by logging to http://192.168.1.1 (leave the username blank and the default password is "admin")
- if you're using a cable connection, set the connection type to "automatic configuration - dhcp" and enable the mac address clone
- if you're using a dsl connection and you have a username and password from your isp, set the connection type to "pppoe" then enter the complete username (ex. [email protected]) and password given by your isp.
- check the "status" tab of the router and see if there's an internet ip and dns, if so, you should be able to connect to the internet
hope this'll help you.
ciao!
Jun 20, 2008 | Linksys Wireless-G Broadband Router
Please help
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
config your router by running the setup cd and that would fix your problem..
let me no know in case if you have any problems ...
Dec 02, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G WRT54G Router Logo
1,513 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
