Question about HP Pavilion dv6000z Notebook
I have the same problem as above. This is a piece of ****. I will switch to Dell next. Hope it is better.
  • 57 Answers
What is the problem you are facing
Posted on Apr 29, 2010
How to switch on wifi switch for dell lattitude E6410
Dell E6410 (and others in that series) have a wifi slider switch on the right side of the laptop above the audio input/output jacks. When it shows red it's off.
Other Latitudes may have the switch in a different place, like in front on the left or on the left side.
For any of them there should be an antenna looking symbol on or next to it.
(It's great to use if you think you got connected to a site that is downloading malware, turn off the wifi immediately.)
Aug 29, 2013 | Audio Players & Recorders
Dell battery plugging point bent...urgent help needed
You are going to have to have that plug in piece re-done with a new piece on the mother board soldered. Who ever told you to remove pieces was way wrong. Now as a result your going to have to have this done or you will not be able to use the laptop. Those pieces are meant to give you better support for the plug in and are also the ground. Take it in and have it done professionally. I would not mess with it anymore.
John
May 20, 2012 | Dell Inspiron 1525 Notebook
Says paper jam no paper in machine
HI,I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue. I ended up finding an object lodged against the switch. Needed a flashlight, plastic giftcard and a tweezers to get it out. Works great now.
Also,open the printer where the paper for printing is put in.
At the back left hand side there is a white long piece and either side a white piece with a small square on it.
Use a longingish screwdriver and push this gently down. It will click back into place quite easily.
Note: this tops the paper from feeding in and needs reseting after a jam.You will know all is OK when a sheet of ordinary paper is put in > touches the feed roller above the white bits, and is level across the paper feed area.
Hope it helps,,
Thanks for using fixya.....
Nov 22, 2010 | Canon PIXMA MX310 All-In-One Printer
Dell laptop is not typing apostrophes unless I mash the key and hold for a long time -- solution?
The keys of a laptop are held above the pressure sensors by two plastic pieces over a piece of rubber. If one or both of these are damaged, you will not be able to properly use your key, and it will take unusual amounts of pressure to make it work. I would suggest either switching to a USB keyboard or ordering a replacement keyboard from Dell. Replacing the keyboard is not an especially expensive or difficult process, and I would be more than happy to share a How To on how it can be done with ease. Hope this helps.
Good Luck,
NOLA Tech
Feb 01, 2010 | Dell Inspiron 1525 Laptop
I cannot activate my Dell Wireless 5720 Sprint Mobile Broadband (EVD0 Rev-A) minicard. Can anyone help me?
There are three places I can think of.
1. In the BIOS (Boot up and press F2 to go into BIOS, find the wireless on/off setting)
2. Function (Fn) key + F2 to toggle between wireless / no wireless
3. A physical toggle switch on the left of the laptop next to the PCMCIA slot, signified by a wireless symbol (antenna with radio waves around it).
Hope one of these helps. If none of the above, try installing the proper drivers from the Dell website and try again.
Cheers.
Dec 06, 2009 | Dell Sprint Wireless 5720 Built-in Mobile...
I have a dell smart step 100 d its constantly rebooting
Hello.
Even though you said that you changed every piece of hardware, just for good measure I wanted to tell you that there are three reasons that a computer reboots itself: 1. Memory, 2. Power supply 3. Operating system problem, such as malware.
Hope that helps, although you may have done the above.
Nov 05, 2009 | Office Equipment & Supplies
2006 Trailblazer AC fan
I believe you must be talking about the inside blower fan tht is not coming 'on'.
It could be the switch tht operates the fan, remove the switch and check for live wire if theres current over there, if theres current thn operate the switch and check other ports for continuity of the current flow.
Its better first though to check the fan itself, it could be faulty or jammed or the brushes wornout.Remove the fan and you can test it out with the help of the car battery and two pieces of wire one to + and the to - , if the fan works thn you will have to proceed further as mentioned above.
Hope this helps.
May 10, 2009 | Chevrolet TrailBlazer Cars & Trucks
Upgrading SSD In Dell Mini 910
This picture should help you identify the location of the SSD in the drive.dell website doesnt say anything about the SSD upgrade.You can check with them for the exact details. 0e93464.jpg
Numbers reference image above: sg_caption1.jpg SSD sg_caption2.jpg WWAN Card sg_caption3.jpg Memory sg_caption4.jpg WLAN Card
Mar 17, 2009 | Dell Inspiron mini 9 - Black , Intel® Atom...
I want to buy a good laptop... I'm unable to decide between two laptops i.e. Dell XPS M1530 and Sony VAIO CS18GN Laptop.... The problem is Dell XPS M1530 screen, if we see it little bit cross the screen...
The answer to this will always depend on who you ask! If this helps I am on my 5th Sony VAIO. I bought my first in 1999 (it was a N505). I have always had excellent performance and reliability from my Sony kit even though it sometimes doen't look the best technically on paper. I have several collegues who have dabbled with Dell equipment and have had poor customer service and reliability problems and have switched to either HP or Sony. This is just my observation and experience...
Dec 23, 2008 | Dell XPS M1530 Notebook
Dell 1600N warming up message
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Sep 16, 2008 | Dell 1600n All-In-One Laser Printer
HP Pavilion dv6000z Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
