Printer Problems I have an hp, 2000xp computer, panasonic KX-P5400 printer and they talk/ parallel to usb cable -it prints a test page- I get one line of my document -then it starts printing page after page of fonts and other numerical codes. What can I do?
  • 4,889 Answers
  • 4,102 Answers
Hi have you installed the correct software that came with the printer?
Also how old is the printer and have you used this printer before on this computer or not
Posted on Mar 24, 2008
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Problems in printing from laptop to laserjet 5L printer
Try with other applications like Ms Word to check.
Jul 06, 2009 | HP LaserJet 5L Printer
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
Printer not responding
Try the HP500Hpgl2 driver, it will work with a USB port.
Dec 13, 2008 | HP DesignJet 450c InkJet Printer
Panasonic kx-p1180 driver for win xp
a couple of questions first. What type of connection are you using? Are you using an ethernet cable or USB?
If you are using ethernet, I suspect either an address problem, IP address, or a firewall problem.
I will be glad to work with you on this, but I really need to know how your trying to connect.
Mar 24, 2008 | Office Equipment & Supplies
CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
Nov 01, 2007 | Samsung CLP-510 Laser Printer
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
