Question about Hotpoint Washing Machines
Dihwasher sdw80 is flashing AL04 and just pumping all the time and not letting water in
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 247 Answers
SOURCE: AL04 flashing on dishwasher screen its a hotpoint ultima thanks
here's the free manual:
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/fdw60_fdw65.html
Posted on Mar 25, 2010
joe_lishman
Joe Lishman
  • 192 Answers
SOURCE: whirlpool dihwasher adp 4552. Water comes into
This is a typical anti flood activation due to the anti flood device (polystireen float and micro switch) at the base of the washer detecting a water leak / spill. This device puts the washer in pump out mode. Check to see if water at the base is causing the polystireene float to activate the switch. Dry the water and rectify the fault (normally a leaky pipe or pipe clamp) and this should solve the problem.
Posted on Mar 26, 2010
Hotpoint ultima DW stuck on cycle does't appear to be heating either
Sounds as though you have a fault in the heating system, it could be a short in the wiring to the heater or it may be the heater itself which as fault. While the machine is waiting to heat the water it will not advance through the program
Jan 16, 2017 | Hotpoint Washing Machines
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
Water coming into sink from dihwasher air line
there is a drain line that attaches to the sink. if water coming up in sink then sink drain is probably clogged.
Sep 08, 2012 | GE Dishwashers
LED lights flashing
maybe the washing machine is ok . there is something wrong with led light . the switch can't in a good contact .
home led lights
May 22, 2012 | Zanussi ZWF1420W Front Load Washer
Hi I have a Hotpoint fdw80 witch is displaying an error code AL10. Please can you tell me what this means so I can decide a course of action. Many Thank's Amanda
I found these error codes for the hotpoint fdw80
AL01 - Anti flood switch operated
AL02 - Valve or connections
AL03 - Time out - drain
AL04 - Thermistor (module)
AL05 - Circulation pump
AL06 - Time out - fill
AL07 - Not used
AL08 - Time out - heat
AL09 - Software recogntion error
AL10 - Heating circuit
AL99 - Communications error - connectors, cables etc.
H20 - Time out - fill (taps)
Now looking at AL10 error. Most often it is the heater element which is not effective due to scale formation. Make a solution of white vinegar and water (50:50) pour it onto the base of the dishwasher. Leave overnight and run dishwasher as normal. Somehow the vineger has to reach the heating element which is an inline heater. I am assuming normally you would use the hotwater connection from the kitchen tap.
If this does not help - depends how soon into the cycle you get the error you will have to replace the heater. I think it would look like this.
Feb 01, 2011 | Dishwashers
Whirlpool dihwasher adp 4552. Water comes into dishwasher, appears to start cycle then water is drained out again and light flashes to show a problem!
Mar 25, 2010 | Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
WATER NOT FILLNG IN GE PROFILE DIHWASHER
It ended up being a simple fix. Soap had dried on the floater (water sensor device) and it could not move, therefore no water was going in. I poured hot water and vinegar into the washer and ran a complete cycle and it is working fine now
Jun 10, 2009 | GE 24 in. Profile PDW7880G Built-in...
Wont wash
The water level sensing switch could be stuck or not functioning and therefore not cutting off the water when it reaches the correct level and starting the wash cycle.
Sep 24, 2007 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
32 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
