Question about LG VX9800 Cellular Phone
My phone only operates when plugged into the charger. it powers up on the battery but shuts off within 5 seconds
    Problem Solver:
  • 9 Answers
Replace the battery first but most likely your phone got wet.....
Posted on Apr 28, 2010
ACER ASPIRE ONE 722 WILL POWER UP FOR 5 SECONDS THEN GOES DEAD
If it's not plugged in then it sounds like the battery is dead. If it is plugged in then your power cord/charger is probably dead.
Jun 26, 2012 | Acer Aspire One 722-0022 : 1.0GHz C-Series...
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
I plug-in my iphone in a fake(non-original)charger to charge my iphone,but within a second the iphone make some noise and shut down.since then my iphone won't start-up.so help me what i have to...
Hello
The charger you are using might have a different voltage rating i.e. either supplying more power or less power. Try charging your iPhone through your computer.
Dec 17, 2010 | Apple iPhone Smartphone
Battery power was very low. plugged Drsire into charger and set phone to shut down mode. when i unplugged it from charger and pushed the 'on' button,the phone vibrated 3 times but will not turn on.have...
Please remove the charger and take the battery out of the phone for one minute. Whilst the battery and charger are out press and hold the power button for 10 seconds to drain any residual power from the phone.
Replace the battery and charger and after a minute power up again.
If the issue is resolved or if it persists please do let me know.
Many thanks for using FixYa
Nov 27, 2010 | HTC Desire Cell Phone
HPZE4200 Shuts off
Hi. it should be the battery that is not charging at all. but there is enough charge to power on but get depleted and turn off lappy. try to charge the battery in another laptop or an external battery charge for lappy.
Jan 26, 2010 | HP Pavilion ze4200 Notebook
Vx9800 powers off when charger is taken out
sounds like you either have bad contacts from the battery to phone or you have a bad charger connection port on the phone or simply a defective battery try buying a new battery on line i have seen them as low as 20 dollars
Jan 24, 2009 | LG VX9800 Cellular Phone
My LG Chocolate won't charge
seems like the battery is dead. just get a new battery
Oct 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG VX9800; Phone powers off when removed from ANY Charger
I noticed this same issue with a phone I acquired... I would look in the plug at the 'bottom' of the phone, the charging/data port.
Most of the time the pins move a bit in normal use, and if the second to the right (with the keypad facing up) pin on the phone's port has moved, or (in my case) touched other pins/grounded out, that was the issue.
I have seen this on a few phones now... It was the plug, or the charger 'worn' out on the plug, causing mis-contact with the pins!
-Cheers
Jun 25, 2008 | LG VX9800 Cellular Phone
Suspect Battery is Dead But Not Completely Certain
In my 30+ years of servicing battery operated devices, I have to tell you that 95% of the time, it's a bad battery.
Question1 : I agree that it should operate on outlet power. Perhaps the battery has a shorted cell and is eating up all of the charger's available current. Chargers have a limited amount of capacity.
Question2: Charge the battery then remove it from the phone. It should be slightly warm to the touch if you touch it within a few minutes of completion. If you have access to a DC Voltmeter, let the battery sit for a couple hours and check the voltage. It should be at least (usually higher) what is written on it. Other than that, replacing it is the only other way.
Hope that helps...
Geno
Apr 04, 2008 | Sanyo RL-4930 Cellular Phone
LG VX9800 Cellular Phone Logo
49 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
