Genica 4Channel Standalone Network DVR Home Digital Wired Surveillance Kit w35 LCD 4 Infrared camera Logo
Posted on Apr 28, 2010
I have a Gen IV DVR that keeps rebooting.
I have a Gen IV DVR that boots and shows the cameras, but after 5 seconds watching the screen without the yellow info page, it reboots. And does this continually. Ver V.1.9.6 software
1 Related Answer
Anonymous
  • 90 Answers
  • Posted on Apr 23, 2010
SOURCE: i have a gen iv 4 ch dvr hooked up in my store. I
Sorry to inform but your dvr has conked off. You need to take it in for repairs.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Hi, Can anyone help me with admin password on signet 4 channel- QV3063. i have tried everything from disconnecting hard drive to removing battery, nothing works.
Possible procedure for another model.
https://www.manualslib.com/manual/757069/Signet-Qv-3020.html?page=15#manual
Quoting: "Chapter 5: DVR Setup -
5.15 Video Mode
This option enables you to select between PAL and NTSC video formats.
This unit comes packaged with PAL format cameras for use in your region; as such
you should not change this setting.
5.16 Factory Reset
Press the [ SEL] button to restore the unit to default, the DVR will reboot and all
settings (including the password) will be restored to the factory default settings.
Caution: There is no confirmation dialog box after pressing the [ SEL] button!
If you have forgotten your password:
And the unit is not recording; keep the system on the main screen, and then press
the [Pause] button ten (10) times in succession, the DVR will then reboot with default
settings. Note: The default password is the [CH1] button six (6) times.
If the DVR is recording, you will need to disconnect the HDD to force the machine
to stop recording prior to resetting the machine to default. "
2answers
Boots up and runs perfect for about 5-10 minutes. Then it beeps twice and shuts down and does a reboot.
Could be a hard drive, power supply or DVR board issue. Try testing each by replacing except the DVR board which you cannot change without a new board. At which point, a new DVR is recommended.
How do I reboot or reset my clover 8 camera DVR combo? Model # COM2208C?
Disconnect the power for about 5 minutes; the wait is to let the internals discharge (5 is minimum, a little longer if you want to), then plug it back in. That will reinitialize the system.
I've got a problem with my cctv cnm 160GB H 264 4 channel DVR I have 3 cameras set up on it and 1 of the cameras have stop working I've checked all power and cables and they are all working fine the...
Remove all the cameras then reboot. If it boots up normally then shut down dvr and add a camera and repeat. If it doesn't solve the problem, the issue is probably a video card or motherboard issue and will need to be repaired or replaced.
For the past couple of days, every show our DVR has recorded freezes a couple of minutes into playing it and the DVR reboots itself. This always occurs at the exact same time on that show. We don't have...
Hi, Mary with Dish Network Customer Service. Since the DVR is the only thing having the freezing issue, it sounds like it maybe a hard drive issue. I would recommend resetting the receiver. Unplug it from the power supply for 10 seconds and then let the receiver reboot itself. If you are still having this issue, I would recommend calling Dish Network and we will need to replace the receiver. Hard Drive issues do not resolve themselves and only get worse over time. Please let me know if I can be of further assistance.
2answers
I have 3 att uverse cable boxes...1 being the dvr unit. The room with the dvr unit only shows a black screen with live tv? When I go to watch a recorded show it works in the other rooms but is a black...
Is the cabling from the satellite receiver to the DVR hooked up right. It sounds like it's in single mode, but with the coax cable put on the wrong way.
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
RCA DVR40
My RCA dvr 40 did the same.I think it was overheating.I vacumed the fan opening and put small blocks of wood under the legs and that worked for about 3 mos. then it said powering up but wouldnt. i'm now replaceing the unit. Good luck
Top Genica Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Genica Home Security Expert? Answer questions, earn points and help others
