WIRLESS NETWORK IS ON AND OFF. SOME TIMES CAN NOT CONNECT, SOME TIMES NO PROBLEM.
  • 99 Answers
Try this:
Try to reset router. Unplug power for a minute. Unplug power to modem for a minute. Plug both back in and see if it resolves the issue.
Hope this helps!
Posted on Mar 24, 2008
2 computers 1 printer
Hi! you must share the printer with that machine witch is directly connected to printer.
Jul 01, 2010 | HP LaserJet 2100 Printer
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
How do I switch on my Wirless Network Connection?
usually some thing like Fn - F2 look at the keys on the top row to see which one it is
Apr 17, 2009 | Computers & Internet
I had my DSL disconnected. I am using cable internet w/Comcast. I've DIR-628 connected to Mot-SB5101 Cable Modem. This setup is working fine. However I'd like to use my old DSL/Router 2wire 2701 to connect...
First you should see a wirless icon on the botom left of your screen wich is on the task bar. The say view wirless networks or what ever it would say then you should see a list of avalible networks at that time. The slect the network that you own an say conect. When conecting it way ask for a WEP password which is located on the router. I hope this will help you.
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
Wirless network problem
If you are able to go online even for 1 minute, then try to change the channel on the router, set it to 11 to minimiz wireless interference.
Aug 21, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
