Question about Sony VAIO VGC-RB53 PC Desktop
My vaio wont turn on and the green light in the back keeps blinki
I have a -rb53 vaio and it wont turn on. the green light in the back keep blinking but i dont know why. can you help?
  • Sony Master
  • 2,404 Answers
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Posted on Apr 28, 2010
Testimonial: "awesome advice... great epertise"
Where do I find the wires that I apprently need to cross to get the check engine light to flash in order to get the codes?
Remove the kick panel just beside the left foot rest on the driver's side.
2) Locate blue wires.
3) Locate black connector. Hold it notch up.
4) With ignition off, insert one of the wires into top row, 2nd pin from left.
5) Turn key to on position, but do not start the car.
6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching blinky light until you get mesmorized.
To clear codes (after problem has been resolved):
1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the
black connector, with notch facing up.
2) Start car. Shut off car. Remove pins.
3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals. yhis is for the 94, 92 should be the same. have a good day !!
Jun 05, 2011 | 1994 Subaru SVX
Changed battery correctly but the on/off green light keeps blinki
you have to hit the button on the wireless base adapter as well as the one on the mouse its self
good luck and pls rate this post
Mar 23, 2010 | Logitech Wireless Access Duo Optical...
The green light on front of tv keeps flashing and tv wont turn on
Howdy,
The green light blinking indicates your TV has a problem. The problem is that each Brand of TV has different codes and with out the Brand and Model number, I can not help you at this time.
Please, count blinking sequence. Model number will be on back of TV.
Recap : Provide Model Number, Brand and Count Blinks.
First though; unplug TV from power source for 3-5 minutes then plug TV & box back into a/c outlet.
Good Luck, BIG IRISH.
Dec 03, 2009 | Televison & Video
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Bluetooth mouse VGP-BMS33
Turn the mouse off. While holding down the connect button, turn it on. Keep holding the connect button untill the green light starts to blink. Now try searching for the mouse.
Sep 06, 2008 | Sony VAIO VGP-BMS33/B
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Turn tv on green light keeps blinking wont reset
Verify Model # off back of set and mo / yr built......critical for
correct solution....For example, if your # ends with.....13, then
a DM module repair will be needed...replace four capacitors...
1000mf 25v 105 degree.....If different model = different solution
....................................T.
Dec 14, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Sony VAIO VGC-RB53 PC Desktop Logo
773 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
