Question about Biostar P4M80-M4 Motherboard
Computer will not boot with 2 gigs of ram.
I am wanting to up grade from 512 Mb (2* 256) to 2Gb of ram.
When I started the computer up the fans turned and the lights came on but i got no video or POST code.
When I tried booting again it I got the all is well beep, but it hung on the bios screen.
Then I tried just one gig and it booted just fine, I tried the same thing with the other, and it worked fine as well.
The memory I am using Is a pair of 1gb Samsung, pc 3200, 184pin.
  • 3 more comments
  • Vizth Mar 24, 2008
    Only has 2 slots. And I'm attempting to put a 1gig stick in each.
    Reread the manual and it says it can handle it.
    Apologies for not posting the frequency.
    they are 400mhz, same size and the same type.
    yes every best as i can tell every thing matches.
    The processor is a P4 Prescott, 3.2Gz, 800MHz.
    yes i have tried each mem 1 at a time on each slot
  • eagle338
    eagle338 May 11, 2010
    How many memory(DIMM) slots do you have and specify the memory modules you have placed in those slots.. Let me know this so that i can help you out.. Sounds like a frequency mismatch..
  • 871 Answers
With regards to iqbal_del , eagle338 this may sound odd and out but, maybe the mobo doesnt support 2 Gb of RAM. it works fine with 1Gb right? but it stops when the other mem is inserted. follow up! Vizth have you tried each mem 1 at a time on each slot ? there may be a possibility that 1 or those rams is not functioning on either slot.
Posted on Mar 24, 2008
  • 655 Answers
Yaa viz eagle is right, its really seems like frequency mismatch. The both RAM must of same size, same type, and same frequency.
Thanks
Iqbal
  • Iqbal Husain
    Iqbal Husain Mar 24, 2008
    see viz here is the detail specification of the board:
    Biostar Socket 478 Micro ATX Motherboard P4M80-M4, 800FSB, Support DDR400, SATA RAID, w/ Video, Audio, LAN, USB2.0
    Biostar Socket 478 Micro ATX Motherboard P4M80-M4, 800FSB, Support DDR400, SATA RAID. With S3 UniChrome Pro Video, AC'97 2.2 6-ch audio CODEC, VIA VT6103, 8x USB2.0.
    Specifications: Processor: Intel Pentium 4 Prescott and Celeron processors, 800/533/400 MHz system interface speed. Chipset: VIA P4M800 / VT8237. Memory: 2 x 184-pin DDR SDRAM, PC3200 (DDR400) DDR SDRAM, Maximum 2GB. Slots: 3 x PCI, 1 x AGP (8x). IDE: 4 x IDE devices, Support for Ultra DMA 66/100/133 Bus Master Mode. I/O: 1 x PS/2 mouse. 1 x PS/2 keyboard. 8 x USB 2.0 ports (4 Rear, 4 Front). 1 x Parallel. 1 x Serial. 1 x VGA. 1 x Lin-out/Lin-in/Mic. 1 x RJ-45 LAN jack. 1 x Audio DJ Connector. 1 x IrDA. 1 x Front Audio Header. 1 x CD-In. 1 x Floppy. 2 x IDE. 2 x SATA. SATA: Two-Channel Serial ATA PHY for support up to two SATA devices. RAID Configurations support RAID 0, 1. Video: S3 UniChrome Pro. Audio: AC'97 2.2 6-ch audio CODEC. LAN: VIA VT6103. Hardware Monitor: CPU/System Fan Speed, CPU Temperatu, System Voltage, Vcore,+3.3V,+5V,5VSB(Stand By),+12V. Size: Micro ATX form factor, 23cm x 20cm (W x L) / 9in x 7.8in (W x L).
    Please also varify that whether the CPU specification is matching with this or not.
    Thanks
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
Want to upgrade ram pc2700 128mb to 512 mb , so i purchased a 512mb ddr1 400mz ram and put it in parallel port but my computer does not boot so i remove the 512 mb ram but problem was as it is now what...
first you check that your ram version.... i means it is compatible with your motherboard...if still prob remains then remove your all ram insert 128 mb ram then restart the system....... upgrade ram should fallow frequency of 512 mb RAM are same as 128 mb ram freqency........if mismatch is occured then it did nt wrked correctly...
Mar 30, 2009 | Computers & Internet
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
Adding more memory to my inspiron notebook
The second slot on the 2200 is under the keyboard.
Jul 31, 2008 | Dell Inspiron 2200 Notebook
Vista Ultimate
need at least 2 gig of ram and 160 gig hard drive to run vista
May 29, 2008 | Microsoft Windows Vista Ultimate Edition
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
512 Mb memory upgrade
well sounds like compatible issue make sure it is ddr,sdr,ddr2 then check the speed and then checkto make sure that it is pushed in all the way in
Oct 18, 2007 | Acer Aspire 3610 Notebook
Biostar P4M80-M4 Motherboard Logo
124 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
