Question about Microsoft Windows XP Professional
Multimedia audio controller drivers not install code28 error and no speaker on taskbar
  • 50 Answers
Download ac97 drivers
Posted on May 01, 2010
The speakers on my D732Z emachines laptop is not working. how can i fix this??
You should ensure that the audio driver is installed and working correctly.
Is there a little speaker icon in the taskbar on the bottom right?
You should also go to the Control Panel and look at the Device Manager. If it shows any errors for your audio device, then you'll need to reinstall the audio driver for your device from eMachine's website. This should be under their Support or Drivers section on their website.
Jul 12, 2012 | Computers & Internet
No sound, drivers can't be found
right click on the red X icon select playback devices there will be a red x on the speakers right click configure them
hope this helps
Jun 27, 2012 | Gateway Computers & Internet
I have no sound and i know my speakers work i get a code28 error i am running windows 2000
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 29, 2011 | Philips Dynamic Edge 4.1 PSC604 Sound Card
Hi. I am running Windows XP on a Gateway 450ROG and I have no audio, mixers or otherwise. I have installed/updated drivers, uninstalled and reinstalled, etc. I also have no audio listed in BIOS. Is that...
the yellow exclamation mark your driver needs updating
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 24, 2011 | Computers & Internet
I cant get any sound from the speakers
hope this helps
Jan 21, 2011 | Bose Companion 3 Series II Multimedia...
No multimedia audio controller
hope this helps
Jan 20, 2011 | Packard Bell (030069) Sound Card
I am getting the error media device not found while installing the sound driver on XP. Please suggest to resolve.th elatop is HP530 with XP sp2
hope this helps
Jan 20, 2011 | Computers & Internet
My speaker's port is not working...i recently reinstalled windows xp n got th multimedia audio controller driver uninstalled...:( i installed realtek HD buh its not working. wot to do now???
Make sure that you have the correct audio drivers for the make of motherboard. Go to start, run, then type in dxdiag and press enter. This will open a box where you can go to the 'sound' tab and check the sound configuration. Also, on the right of the taskbar, right click the speaker icon and open volume controls. Make sure all of that is set up correctly. If you still get nothing, go to control panel/system/hardware/device manager and check that it shows your sound controller under sound and game controllers. If it doesn't, you might need to turn off, clear the CMOS memory, start up, and re-install drivers. Good Luck! :)
Jul 20, 2010 | Intel ESS ES1868F Sound Card
No Sound from the Desktop
go into control panel click on sounds and audio check mute is unticked and tick vol icon on taskbar
May 16, 2009 | Computers & Internet
Code28
It means the sound drivers are not installed.
Just let me know the maker name and exact model no of your desktop  or laptop....
Aug 24, 2008 | Edirol UA-4FX External Sound System
Microsoft Windows XP Professional Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
