Question about Maytag MGS5870 Gas Kitchen Range
F1 error on a MAYTAG Super Capacity plus gas oven MGS5870, I think. How can I tell if this is an ECR problem, oven sensor, or cable?
catriver
  • 878 Answers
SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Posted on Jun 05, 2007
elhomspam
  • 58 Answers
SOURCE: Maytag gas super capacity plus
F9 relates to a bad door latch
either you need to reconnect a rod
or you have a bad latch(sometimes solenoid asembly depends on age)
Posted on May 02, 2008
woodchuck789
  • 4059 Answers
SOURCE: maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Posted on Sep 18, 2009
  • 478 Answers
SOURCE: Every time we try to preheat oven it stops after a
controle board bad
Posted on Jan 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Maytag Gemini mer6770aw
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
I have a maytag super capacity plus gas oven. When I preheat the igniter lights but the oven does not light nor do I smell gas.
Probably a weak ignitor does not draw a high enough amp draw to power the gas valve do not see many gas valve failures if you have a clamp on amp meter from the back of the unit clamp on the lead to the ignitor should be 3 amps or higher
Dec 29, 2014 | Maytag Kitchen Ranges
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag super capacity range and I am getting an F9 error message on the display. I can't find the model number and it is not where maytay said it would be on the range (according to the site)
The F9 fault code means door latch problem. Check door latch hardware. Here is a list of the Code Description for your unit. Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. DON'T FORGET TO RATE THIS POST!!
Sep 18, 2010 | Maytag Kitchen Ranges
I ahve a maytag mgs5870 adc. Oven will light then go off and on.
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 05, 2010 | Maytag MGS5870 Gas Kitchen Range
Am getting an e1 f1 error code on whirlpool super capacity natural gas oven model sf385pee please help if you can, thanx
HI. this will be a EEPROM check-sum error code. Follow the instructions below to address this issue.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Oct 14, 2009 | Ovens
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
Maytag advanced cooking system/the super capacity plus
My Maytag , advanced Cooking system , super capacity gas stove has a problem with the oven. It looks like it lights, but most often, doesn't heat up, and I can sometimes smell gas. Anyone know what what cause this?
Jan 20, 2009 | Maytag Ovens
Maytag MGS5870 Gas Kitchen Range Logo
370 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
