Question about Motorola Mobility SLVR L7 Cellular Phone
Phone not holding charge with new battery
    President:
  • 1,561 Answers
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Posted on Apr 28, 2010
5 Suggested Answers
SOURCE:
  • 173 Answers
SOURCE: Won't hold charge
Are you sure that its the battery losing charge in 1 phone call?? Or does the phone just die during the call? If so then the contacts from battery to phone and phone to the board are loose and need to be adjusted. But since this is an ancient model, you might want to look into an updated verison instead of spending money to fix it
Posted on Mar 14, 2009
toy_ladi
  • 484 Answers
SOURCE: battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Posted on Jun 19, 2010
Testimonial: "yes this was quite helpful....so it could be the charger, my local store has offered to loan me a charger that they know works, so I will try that next....if it turn out to be one of the other problems that requires replacing parts, are parts available and if so where ?????"
  • 17 Answers
SOURCE: battery not holding charge
That sounds like typical battery life for that phone.  When I owned one that's what I got on the weekends when my call volume was lower.
Posted on Dec 15, 2008
SOURCE: my sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Posted on Apr 14, 2010
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Does not hold battery charge
Since you have a new phone and a new battery and is still doesn't work ... the first step should be to take it back to where you got it ... have then evaluate it for possible replacement.
May 16, 2010 | LG Shine KE970 Cellular Phone
My sanyo pm 8200 wont hold charge!
Take care.
Apr 14, 2010 | Sanyo PM-8200
My phone wont hold a charge
Battery is done. Won't hold charge. Get a new battery at Fry's or elsewhere if your phone isn't ancient and you love it. Try to find a lithium-ion. I used to buy replacement batteries from Belkin on my older phones and they were quite good. If your phone is ancient, can't find battery or phone is just outdated get a new phone from your carrier. From free with new contract all the way to a few-hundred dollars for a smart phone. You may even have an upgrade discount waiting with your carrier. You'll find something in between that suits you.
Jan 30, 2010 | Motorola Mobility i730 Cellular Phone
My philips cordless phone wont charge with new batteries
try the old battery if you still have it then see if it holds a slight bit more once charged.If it does then go back to the seller of the new battery for a replacement.
Aug 31, 2009 | Philips SINGLE HANDSET USB VOIP PHONE
My new phone wont hold a charge. Is this common
maby battery are damaged insite buy new battery or let store check battery maby waranty
normaly not on batterys
Aug 24, 2009 | Motorola Mobility MOTOROKR EM330 Cell...
My phone won't hold a charge. Do I need a new battery?
Most likely yes, try taking the battery all the way out and putting it back in. Also, allow the battery to drain completely and then charge from there. If it never gets a chance to drain completely this can cause problems.
If after these two steps it still isn't holding a charge then you will need a new battery.
Thanks
Jul 13, 2009 | LG CU500 Cellular Phone
Will not hold charge
you need to change the battery...
May 14, 2009 | Samsung SCH-u340 Cellular Phone
Power is draining
How long have you had the phone ?
your Phones battery could be potentially Leaking, and it may not be able to hold a charge anymore after how you have described the symptoms. Batteries that can no longer hold their charge expel all of the energy they would normally use to power the phone, and this generally causes excess heat around the battery compartment,
i would suggest purchasing a new battery, preferrably one created by Motorolla Specifically for your phone, when you have the battery, keep the phone on charge for a long time to ensure the battery holds its maximum charge !
This should solve your problems
Oct 13, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
1,848 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
