Question about Mitsubishi WD-52525 52" Rear Projection HDTV
It doesn't power up when you turn on tv - Mitsubishi WD-52525 52" Rear Projection HDTV
  • 59 Answers
Is there green button when you press it if no then it is power supply, but before all you should make sure about outlet and the ac cable first, is stand by mode light up if no power light or stand by light then it may audio board because it act as audio and crossover power and output.
but get another opinion .
good luck
Posted on Apr 28, 2010
My Veon 32" tv wont turn on
Help my veon tv power is on sound is work but the screen is black ..i dont know what to do ?
Apr 19, 2013 | Televison & Video
SRP4004/27
Let's try to sort this out. You have a universal remote control which you want to use with your RCA TV. You turn on the TV, press and release the TV button on your remote, and enter an RCA TV code. You then press the ON-OFF (or POWER) button and the TV turns off. If not, you repeat the process with other codes until you find one that turns the TV off. If you are successful, you should be able to turn on the TV and channel up or down through all available channels in your area. If I am missing something, post a reply
Nov 16, 2012 | Televison & Video
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
Why doesn't my magnavox led tv turn on?
if just an stand by indicator at the front panel check for bulging capacitors at the power supply board.
Sep 30, 2012 | Funai Magnavox 19" Class 720p 60hz LED TV...
Samsung pn50c450b1d had a power surge doesn't turn on
if able examine the power supply board in the set, if not able consider having a repair shop look at the set.
Aug 26, 2012 | Samsung PN50C450B1DXZA - PN50C450 50 720p...
Can't turn it on - the power lught is flashing
it is possible that the tv is in its power management system because it was over heated. Leave it alone for a couple hours and if it still doesn't turn on, try unplugging and plugging it back in.
May 24, 2011 | Samsung LA26A450 26 in. LCD TV
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
