Question about Dishwashers
Stuck on 82 minutes
Whirlpool quiet partner iii stuck on 82 minutes and wont change cycles
SOURCE: whirlpool gold- quiet partner III
I had a similar problem. So I bought a new computer for it. It didn't fix the problem. It turned out to be the button pannel. With all of moisture surrounding it steam go into the buttons and caused all kinds of faulse info that the computer could not interpt. Had to buy new button pannel and problem was fixed.
Posted on Mar 29, 2008
huuum
  • 750 Answers
SOURCE: whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
rhinostack
SOURCE: whirlpool quiet partner III clean light blinking green
press:
heated dry
normal
heated dry
normal
then cancel..... wait until 2 minute cycle is done. open and close the door and make sure it is closed.
Then run another cycle. saw this on another post and it worked for me. They said that if it did not reset then either the latch has a bad connection or the heater for the water is bad.. it must register that the door is closed in order to actually start the heater for the water. I hope this helps you as well as it helped me.
---Rhino---
Posted on Dec 22, 2008
appldoctom
  • 311 Answers
SOURCE: Whirlpool gold Quiet Partner III is really loud.
now you'll be able too hear under the tub if motor bearing was the noise.put a long tool to the motor and close to you ear,see if that gives you a clue[i don't want you to give up on it if its not the motor]if was to buy that motor wholesale it would be around 50 bucks or so ,retail about 100 or so.so if replacing depends on the shape of the rest of the unit.[i have sold and installed many]new dishwasher on sale 300$ or so,plus your time to install.but if new its a forsure thing.so depends how much motor,how sure you are wiill solve problem,what shape unit in.hope that helps. God bless ,tom
Posted on Jan 12, 2009
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
My whirlpool Gold Quiet partner III won't wash. Dishes come out greasy.
Add Jet Dry and run a cycle with dishwasher empty with bleach and should start working good
Nov 19, 2010 | Whirlpool Dishwashers
Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool gold quiet partner iii bearing noise
if its noisy when washing check chopper assembly. if its ok change the sump pump assembly
Feb 09, 2010 | Whirlpool Dishwashers
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Dishwashers Experts
Owen Barnes
