Question about Everex CloudBook CE1201V Netbook
HELP when I installed a 1Gb 667MHz pc2-5300 pc2-4200 DDR2 Corsair Ram stick in my everex cloudbook. It wouldn't boot up not even the BIO's. I tried the old RAM which was a 512 DDR2 sdram 677mhz adata RAM stick it still wouldn't boot up.I really need some help.
    Problem Solver:
  • 13 Answers
Just trying a stick of RAM shouldn't kill your system. Think dirt. Is there a chance that the contacts on both the laptop and RAM are dirty? Are you sure that you installed it correctly? It's easy to get it wrong in a laptop. It's real easy.
Posted on Apr 28, 2010
Change memory Everex CE1200V
Your Everex CloudBook can support up to 1024MB (1GB) of computer memory. For optimal performance install the maximum amount of memory in each socket., Your Everex CloudBook uses PC2-4200 type memory.,
remove the battery than remove all ten screws than with a credit card u should flip from side to side the cover off
Dec 14, 2011 | Everex CloudBook CE1201V Netbook
I have an emachines t5082 and tried installing 2GB (2x1GB) they are a 2-pack, DDR2 6400's The board sees 1GB but when I put both in it won't even give me a boot screen or anything, just a black screen. Is...
eMachines recommends DDR2 at 533MHz.
(PC2-4200)
A lot of ram memory manufacturers, state you can use DDR2 at 667MHz. (PC2-5300)
This is a logical statement due to the fact that a lot of motherboard chipsets, (Northbridge chip specifically),
will allow ONE step up in ram memory frequency rate.
You are going Two steps up.
Who told you this would work?
This is erroneous.
(Mean that in a nice sort of way)
PC 6400 is DDR2 at 800MHz.
Your eMachines T5082 motherboard uses an ATI Radeon Xpress 200 motherboard chipset.
This chipset will only support DDR2 at 667MHz at best.
http://en.wikipedia.org/wiki/Xpress_200
Suggest you send that ram back, and get PC2-5300.
Jan 07, 2010 | E-Machines T5082 PC Desktop
I have an Acer Aspire 3680 notebook with 512mb Ram.What type of Ram do I need to upgrade
it must be DDR type of Ram. dont use DDR2 ram.
you can use 1 GB DDR of Ram
Oct 12, 2009 | Acer Aspire 3680 Laptop
Not upgrading 1gb ram to asus p5vdc-mx
yeap its the wrong memory.
max mem is 2GB DDR2 533/400 non-ECC, 2 x 184-pin DIMM
or you can use. 2GB DDR 400/333/266 non-ECC,
Note, you cant use both DDR2 and DDR in the same time. so set both memory stick as same type.
so if you set 2x1GB DDR2 533 you get the optimized speed.
hope it helps.
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Can i use 2 diff brands of RAM simultaneusly 1gb corsair ddr2 667 and 1gb transcend ddr2 800 for P965T-A
It is better to use the same brand.
These to brands might work together, you don't know until you put them in your computer and test it.
May 15, 2009 | EliteGroup Computers & Internet
My system won't boot after installing a new 2 GB DDR2 RAM
Try cleaning it edge connector with soft eraser both side and dont try to touch the pin. If it doesn't help you got a defective one.
Apr 28, 2009 | ASUS M2N-MX Motherboard
My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
Mar 17, 2009 | Acer Computers & Internet
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Abit AW8-MAX Motherboard
Everex CloudBook CE1201V Netbook Logo
98 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
